Yikes' Sterling isnt a floater.kylesgorter wrote:True that! I think ill run my 8.8 till its good and dead and then I think ill take a page outa yikes book and swap to 10.25 floater. Not convinced on 9in and I doubt ill have the mass $$ for a built 9
Best 9inch year to buy for my bronco
Re: Best 9inch year to buy for my bronco
Damn that sucks.... Mine will be! Haha what kind of axle retention does his have. I thought all sterlings were floaters guess I got incorrect info on some of this stuff
His is a hybrid. It's a 10.25 center, with 9" outers.kylesgorter wrote:Damn that sucks.... Mine will be! Haha what kind of axle retention does his have. I thought all sterlings were floaters guess I got incorrect info on some of this stuff
Sterlings and Ford use the same spline pressure angle.
I'm actually replacing my builtish 9" with a Sterling center. Going with 5 lug Dana 60 full floater outers which use a different pressure angle.
Does that mean custom length tubes, d60 spindles and prob disc brakes? That would be awesome on big bertha
Thats for the Bronco. The crew does fine with a stock Sterling.
Has anyone bent an econoline housing? If so, where?
They can all be bent or broken, it just depends on how hard you want to beat it. It usually happens in the tube where it is welded into the banjo center section, even though it is fish mouthed in there.dtbback wrote:Has anyone bent an econoline housing? If so, where?
We have bent and cracked two aftermarket Speedway Engineering housings, both had 0.250" tubes, one was DOM tubing, and the other was 4130. The first cracked at the weld as described above, so the second had wider trussing. The crack occurred at the end of the trussing on the second one. The second one had more than 1/2" of toe in bend at the tire before it was replaced. Have not had any trouble with the early Ruffstuff housing with 0.3750 tubes and only their formed truss across the back in more than 5 seasons. We also gained a full two inches of clearance to the ground at the center of the axle.
- fomoco51
I've found alot of 31 spline econoline 9" rears. I heard that the newer econolines with a 10.25 are wide as well, but can't find any info on em.
- S00TLYFE
- Bronco Info: IT RAPTOR NOW
i pulled an f150 9" in the boneyard and stashed it, after doing research i realized i probably would have been better off with an aftermarket housing though. Couple buddies have had good luck with factory 9s with a tabzone truss, and have even run stock housings, they beat on the trucks hard, but they are behind 4.0 and 3.0 ranger motors running 35s.kylesgorter wrote:True that! I think ill run my 8.8 till its good and dead and then I think ill take a page outa yikes book and swap to 10.25 floater. Not convinced on 9in and I doubt ill have the mass $$ for a built 9
