Kritter's 96 Bronco
Kritter's 96 Bronco
Shooting to have suspension on by san felipe. Custom shocks, gears, bumpers, rear area rack will have to be for baja 500.
- 96-Bronco-004s.jpg (205.3 KiB) Viewed 8007 times
- 96-Bronco-003s.jpg (187.31 KiB) Viewed 8007 times
- 96-Bronco-002s.jpg (158.52 KiB) Viewed 8007 times
- 96-Bronco-001s.jpg (172.48 KiB) Viewed 8007 times
Last edited by shockseals.com on Fri Mar 05, 2010 9:03 am, edited 1 time in total.
Re: My foundation...
other than the rear quarter from a tire blowout its pretty dam clean and straight. Tons of service work done on it before it was put in the garage 4 years ago too.
Nice and Clean, I like it.
Where in San Dimas are you, I work in San Dimas.....
- Bronco Broker
Slap on some Autofab rear quarters and you won't have to worry about that banged up rear section.shockseals.com wrote:other than the rear quarter from a tire blowout its pretty dam clean and straight. Tons of service work done on it before it was put in the garage 4 years ago too.
Nice bronco by the way. Any interior pics?
Day 1
4 hours put in tonight...all suspension stripped other than coil buckets. Front and rear diffs were sent out for 4.56s, detroit in rear. Should go together nicely this weekend. Quite a few areas to prep for weldwashers and misc. welding but going to be a fun project.
Thanks to the guys at Crossroads Fabrication (http://www.crossroadsfabrication.com/) for lending the shop and a few hands. I figure with their track record of no losses and no prep related failures in 3700 and class 3, having them lending a hand with the prep should make this thing solid as a rock.
I live off 3rd street. Shop is off Gladstone across from new costco.tcm glx wrote:Nice and Clean, I like it.
Re: Kritter's 96 Bronco
looks awesome kritter! jon does amazing work and is also a hell of a nice guy!
Ollie Penchansky
Penchansky Brothers Racing.
Nice bronco! I know they do good work there...Ive know john krellwitz for years...awesome fabricator!
Sneak peak from day two....
- 25599_1356031788329_1457498263_908710_1142927_n.jpg (66.16 KiB) Viewed 7855 times
Day 2 went off well other than a broken Snap On Torque wrench that stripped out a bolt and kids dont like air chisels.
Back to work
Back to work
- Bronco Info: 1990 Bronco EB
It looks Killer, Jon and the guys are all great People. I wish mine were there too.
That's some good progress! Coil-buckets with only a rear mounted shock are soooo much easier to install on EFI trucks... good choice!
I wonder if the coil-buckets Brian and I just picked up are foreman-built? They look almost identical.
Im looking to get a set of coil buckets just like this...where can i get them?
Brian and I bought ours off some guy at the swap meet. Kris bought his used. Autofab is the only shop I know of that currently builds and sells them.
Rwies wrote:Im looking to get a set of coil buckets just like this...where can i get them?
Yikes is selling a set .......
Day 3...only a couple hours today. All holes drilled, radius arms and buckets nut and bolted. Rear buttoned up for most part.
[img]
[img]
Looking good, Kris! You going to have it done before the 250?
It will be but its going to magnaflow for some cat and exh development on wednesday. I figure I should take it local first anyhow considering I have only put 300 miles on it since I bought it.
Today:
Finished kit install still waiting on diff.
New hoses and t-stat
Oil Cooler removed from loop
Oil Change
PCV valve
coolant change
Plugs
cap and rotor cleaned
Rear window diagnosed
Interior Door handle mount area strengthened
Tuesday I will have everything to finish it. Hope to pick up steering tomorrow steve so let me know.
Today:
Oil Change
PCV valve
coolant change
Plugs
Last edited by shockseals.com on Mon Mar 08, 2010 6:34 am, edited 1 time in total.
