DD GFB
Re: DD GFB
I run the J40's theyre 3" wide like the originals. A little stiffer and not as much sway. Alot of guys on here run the f53's which is a 2wd 2.5" wide spring. You get a softer pack and more movement out of the rear. Both have pros and cons.
EDIT Also, I believe its the F64 for the front. Ran both the deavers and the ones from the camburg kit. (superlift?) I liked the deavers but it ran a little to tall with alignment. Remember its a 5.5 soft coil so it sits a little higher than a 4". They ride good but I liked the camburg coils better myself.
- Bronco Info: 1992 Custom. 302/5 speed/ manual 4x4 and hubs.
Re: DD GFB
Aren't the J40s 5" of lift? Can the Solo C&T beams take 5.5 inches of coil lift if I ran the Deaver front coils? Or do I shop elsewhere? I figured 5.5 front and 5 rear would level my truck out a bit.
Re: DD GFB
Negative! F64's are deavers 3" wide 3" lift springs. I ran those on my last bronco, and really liked them. Sadly, deaver no longer mass produces them, but i'm sure they will make up a set.hobbyturnedobsession wrote:EDIT Also, I believe its the F64 for the front.
- Phoenix0783
Re: DD GFB
Thank you I know I was missing something! I had an old pic of my coils and just saw the f64.
- Firetwig
- Bronco Info: 1978 Ford Bronco 1996 Ford Bronco
Re: DD GFB
Yep Sean, the same set-up I am planning!
Speaking of which, any problems in running this with 6inch pro-comp springs instead of 4in?
(Instead of starting my own, since Sean and I will have twinkie lifted trucks pretty much lol!)
- Firetwig
Re: DD GFB
So be good putting it up for trade for a 4inch lift springs?hobbyturnedobsession wrote:You won't be able to align it.
- bajascott
- My belly is my best friend
Re: DD GFB
ideally yes....Firetwig wrote:So be good putting it up for trade for a 4inch lift springs?hobbyturnedobsession wrote:You won't be able to align it.
- Firetwig
Re: DD GFB
I didn't want 6inches of lift anyway, but junkyard Bronco had them and they are 20 bucks in almost new condition. Always someone trading up for 6inches, so I'll trade "down" for 4inches of lift. I'll call ya tomorrow mate!bajascott wrote:ideally yes....Firetwig wrote:So be good putting it up for trade for a 4inch lift springs?hobbyturnedobsession wrote:You won't be able to align it.
Re: DD GFB
Adding more lift also creates some issues at full bump and further taxes steering. And you would need to run a larger eccentric bushing which will put the upper ball joint at a more severe angle.
- Polarcub
Re: DD GFB
With regard to the J40s/F64s for the rear. I ran the F64s for awhile and while they are agood spring I would really recomend going striaght to the J40 and extended shackles. The ride is better. If you run the F64 with the factory block your height will beright about that of a 4" lift on factory shackles, I experienced a great deal of axle wrap with that set up. Once I changed to the J40 and got rid of the factory block the height was just right. FWIW the deaver coils although listed at 5.5 settle about an inch rather quickly. They are a bit softer and in fact the other 4" springs the ride height works out to nearly the same.
Jeremy
Re: DD GFB
http://www.youtube.com/watch?v=Po5ZbmxLnFI
+3 beams, 2.5x14 coilovers, deavers with basic bilstein 5100 shocks.
SMT Racing: Co-Dog
- Bronco Info: 87 Bronco with some Autofab parts held on with bailing wire and duct tape
Re: DD GFB
http://www.autofab.com/ is a great source of information. John is a great guy and can usually make some spot on recomendations.
Re: DD GFB
Rear is pretty sketchy in that video...95_Bronco wrote:http://www.youtube.com/watch?v=Po5ZbmxLnFI
- Phoenix0783
Re: DD GFB
How would that be fixed?shockseals.com wrote:Rear is pretty sketchy in that video...95_Bronco wrote:http://www.youtube.com/watch?v=Po5ZbmxLnFI
Re: DD GFB
Shock tuning.Phoenix0783 wrote:How would that be fixed?shockseals.com wrote:Rear is pretty sketchy in that video...95_Bronco wrote:http://www.youtube.com/watch?v=Po5ZbmxLnFI
- Phoenix0783
Re: DD GFB
I realize that, but what should be increased and what should be decreased for compression and rebound?Nick wrote: Shock tuning.
Re: DD GFB
all it is, is deavers with stock replacement 5100...Not mine, just a good friendsshockseals.com wrote:Rear is pretty sketchy in that video...95_Bronco wrote:http://www.youtube.com/watch?v=Po5ZbmxLnFI
SMT Racing: Co-Dog
Re: DD GFB
The rear looked like it needed less compression and more rebound.... but it's a moot point with 5100s on the back. It's kinda hard for a 5100 to keep up with a coilover.
I've always prefered to have more/better travel in the rear.
