Saginaw Pumps W/ Brackets
- S00TLYFE
- Bronco Info: IT RAPTOR NOW
Re: Saginaw Pumps W/ Brackets
Bump, 1 460 and 6 5.0/5.8 setups fresh from sandblast this morning.
Killer looking pump brackets and lines. Might have to update my pump lines. These are direct fit? No adapters?
- S00TLYFE
So, first off you will lose your factory cooler, other than that they’re plug and play for the most part. The hose end on the slip on side I usually have to ream out a little bit to slide it on easier as it’s just a tad smaller, but with AN fittings that’s the only way to make it workStan the Man wrote:Killer looking pump brackets and lines. Might have to update my pump lines. These are direct fit? No adapters?
- S00TLYFE
bump, currently have
1 460 setup
3 5.0/5.8
1 460 setup
3 5.0/5.8
Wanted to show off my setup that Travis just recently built up for me. I’m super pumped on the product and service! Thanks again dude!
- Bronco Info: 89 BrF150 on 33x17's no lift. Stroked and built 302, with Mustang electronics
What about filter and cooler? Thermal bypass; it gets cold -where I live?
- S00TLYFE
i dont do any of that stuff but you can adapt one inside on the low PSI side with the factory econoline hoses. I'll glad sell you a pump assembly and you can figure out hoses if you want, there just isnt enough demand for what youre asking for it to be worth my time to R&Dfreechrisb@gmail.com wrote: ↑Wed Sep 09, 2020 3:31 pmWhat about filter and cooler? Thermal bypass; it gets cold -where I live?
- S00TLYFE
Oh, and if you use my hoses with AN fittings, you lose the oem "cooler" but if you run econoline hoses it retains it, hope this helps.
Yes, thank U for U'r response. I actually have van bracket, new RedHead gearbox, and a new/reman Ford saginaw pump -with a remote reservoir fitting on top of it? Where U'r cap would go? This has me kinda wondering; guess go out and get a sealed canister type - mount it on the firewall or something. Only running 33s and no ram; though just want to do it once and it b right. Magna-Pure filter, thermal by-pass and cooler....seems like alot going on here. Thanks for any and all recommendations and help.
- S00TLYFE
i actually just had my first encounter with those weird pumps, you can also just swap it out for one that takes a cap. i think the remote resi ones came off of RVs but havent been able to confirmfreechrisb@gmail.com wrote: ↑Fri Sep 11, 2020 1:56 amYes, thank U for U'r response. I actually have van bracket, new RedHead gearbox, and a new/reman Ford saginaw pump -with a remote reservoir fitting on top of it? Where U'r cap would go? This has me kinda wondering; guess go out and get a sealed canister type - mount it on the firewall or something. Only running 33s and no ram; though just want to do it once and it b right. Magna-Pure filter, thermal by-pass and cooler....seems like alot going on here. Thanks for any and all recommendations and help.
- S00TLYFE
bump, currently have 5 5.0/5.8 setups ready to go, 2 460 setups
- S00TLYFE
bump, two 460 and 4 5.0/5.8 setups
- S00TLYFE
bump, just picked up 7 more from sandblast and assembled ready to go
- THEJESUS
Sent text
- S00TLYFE
bump, currently have 3 5.0/5.8 setups in stock, anyone who buys before 10 PM PST 1/14/21 ill throw in a free shirt or if you just want to buy a shirt, hit the link in my signature haha
Do these pumps work well with a Hydraboost brake setup and a ram assist inline?
David Wright
David Wright
- S00TLYFE
Hey Dave,Wrightracing.net wrote: ↑Fri Jan 29, 2021 8:45 amDo these pumps work well with a Hydraboost brake setup and a ram assist inline?
David Wright
guys run them with both, no personal experience with it, im happy to sell you all the components minus the pump, because youll need a different one than i sell (Extra port) thats PN BBB INDUSTRIES 7322151, let me know!
Ok, thanksS00TLYFE wrote:Hey Dave,Wrightracing.net wrote: ↑Fri Jan 29, 2021 8:45 amDo these pumps work well with a Hydraboost brake setup and a ram assist inline?
David Wright
David Wright
- S00TLYFE
bump, currently have 3 of these ready to go for 5.0/5.8
- S00TLYFE
bump, have 3 setups ready to go, brackets are sandblasted, pulleys are sandblasted and powdercoated, reman pumps installed. $300 plus shipping or picked up in Buena Park or South Bay Los Angeles
