New End Game Ford F150 SuperCrew
- funinthesun95
Re: New End Game Ford F150 SuperCrew
Well bigger is always better....why keep it the same
- IMG_1030.jpg (32.61 KiB) Viewed 1341 times
- powa_ranga
- Bronco Info: 2012 raptor, 1995 ranger,2000 7.3
Man I thought I had the biggest shocks around...now you're just showing off
- funinthesun95
Yours are still bigger with the cactus coolers.....hah
I don't even know if I can fit these things. so we will see if I use them.
- funinthesun95
Next up
380HP please. We have a 2003 lightning drive train wiring PCM and gas tank. I did some research This is the easiest way to upgrade. Ford kept most of the same harness and wiring so this keeps me from doing a complete rewire and keeps OBD2 scanning still for trouble shooting.
this is not a race truck so I have the ability to stop and relax anytime I need too....I will also add help for cooling in a few different ways( I know heat will be one of the issues). I will keep it stock and party no crazy tunes for add HP and smog legal. Drive it to the dirt drive it home.
- IMG_1044.JPG (65.34 KiB) Viewed 1310 times
- IMG_1043.JPG (35.76 KiB) Viewed 1310 times
- IMG_1042.JPG (43.05 KiB) Viewed 1310 times
Need to help you with this so it will be easier when I put one in a Crown Vic
- funinthesun95
yes you do.....
- powa_ranga
Very nice, what's your plan for fuel pump, intercooler, and gauge cluster?
- funinthesun95
powa_ranga wrote:Very nice, what's your plan for fuel pump, intercooler, and gauge cluster?
current set up is Dual Bosch pumps I will check flow on them.
I will add a liquid tank for the stock intercooler and place heat exchange in front of radiator or maybe back with tanny coolers if I feel it will flow ok. I will also add electric water pump like stock uses to move the coolant it will be one more thing i will need to check but can carry a second pump easy as needed.
Gauge cluster might keep stock and add boost gauge the lightning cluster, the only gauge that different is top right corner. F-150 has battery lightning has boost I think ....
- funinthesun95
so your saying they might be too big.....like just a little?
40 inch BFG, while the motor out I figured why not....not sue they will fit with the HM kit I have tho
- IMG_1077.jpg (21.29 KiB) Viewed 1274 times
- powa_ranga
Radical! Sounds like you got a pretty good game plan!funinthesun95 wrote:powa_ranga wrote:Very nice, what's your plan for fuel pump, intercooler, and gauge cluster?
FYI those ford electric intercooler water pumps like to fail due to the relay or the pump itself...I used to replace the relay pretty often on the Cobra and the Harley truck and I would also pull the motor apart once a year or so just to snap the brushes and blow it out...what sucks is you never know if they are actually running or not unless you put eyes on it or have a way to monitor it...they wont throw a CEL, it will just keep pulling timing until it is in a safe zone which sucks cox...always thought it would be cool to add a small indicator light on the backside of the pump to know when it stops turning, or a simple water temp probe would work. Just a thought.
- funinthesun95
the temp probe would mean it heating up so it not working kinda thing a warning sign? copy
looks like I have a new go to for question on this as you have owned them....I forgot you told me about the Harley you had.
- powa_ranga
You either need a way of readily monitoring your downstream IAT (Intake air temp) after the cooler, or you could monitor your water temp in the cooler system since it's completely separate of your engine coolant...or just pop the hood every now and then to see if your res tank is moving water, if the pump isnt moving then the water just sits in the other cooler under the blower, gets hot, and will start pulling power due to high IAT temps which will make it lean out if doesnt pull timing...the problem is that the pumps will intermittently work quite often due to the relay or pump itself. You are welcome to call me if you want better clarity.funinthesun95 wrote:the temp probe would mean it heating up so it not working kinda thing a warning sign? copy
- funinthesun95
I have been Saturday driving this rig.
- IMG_1251.jpg (69.72 KiB) Viewed 1234 times
- funinthesun95
ok I have made 4 210 mile loops in this thing street and dirt mix.
drive out, drive home, has to be one of the coolest things you can do
- funinthesun95
The light set up on this truck makes me smile every time I get to use it. The rear floods makes life nice when working on trucks.
- 56360141933__E8954234-0F9C-41D1-946F-8FD02892AE9E.JPG (17.66 KiB) Viewed 1132 times
- 56360139658__A2059471-286A-4A1B-BEA1-F32E760E2AE6.JPG (16.92 KiB) Viewed 1132 times
- funinthesun95
The next AM at home, she gets a bath with the kids help.
I also get to look her over for any issues that make have come up.
- IMG_2859.jpg (27.03 KiB) Viewed 1122 times
- funinthesun95
ok it been a while.... about to re group and work on upgrades.
Sweet. Damn houses getting in the way of truck stuff. I here you have a smokin hot interior designer though hahaha
Sent from my moto x4 using Tapatalk
- funinthesun95
lmao ....yes Sunee is extremely attractive and easy on the eyes. hahah
yes the house stuff has sucked.
- funinthesun95
anyone in the market for Kenwood TK-790 radios?
110w and 50w
110w and 50w
