95 spindle for two piece seal
I need a spindle like the title says. It has to be the newest style for ABS, 5 bolts and for the two piece seal. Somehow my passenger side is bent down??? No idea how that happened.
But...... I'll obviously pay for it and shipping, or if you're local, for it and some beer. I have a trip coming up in 3 weeks so I'd love to find one. Thanks!! Text will work best.
Darren
619-944-5991
Darren
619-944-5991
I would try Bobby at solo. I see a bunch there all the time.
Good lookin out. I've been googling for a while and it seems that spindle is nowhere to be found.
Or if anyone has 5 bolt spindles and hubs from an earlier year I'm willing to change those out.
I have a set but they are non-abs
I wonder if the bolt pattern on non abs are the same as the abs ones? I've deleted my abs so I don't need it. How much do you want for the set?
Re: 95 spindle for two piece seal
I have a spindle also.
For the two piece seal?BDKW1 wrote:I have a spindle also.
The bolt pattern is the same. Only difference is the spindle flange doesn’t have the notch for the abs sensor to stick through. You can have the hubs, rotors, spindles, knuckles for $150 if you want them.birdco85 wrote:I wonder if the bolt pattern on non abs are the same as the abs ones? I've deleted my abs so I don't need it. How much do you want for the set?
Travis do you have the calipers and hardware also? My brakes won't change over.
They are the bolt on calipers. Probably same as yours. Off a 94. You can message me a (951)452-4050birdco85 wrote:Travis do you have the calipers and hardware also? My brakes won't change over.
- funinthesun95
I think I have a set as well of 5 bolt knuckles and spindle
Thanks willie.
I got the set from Travis so I'm good to go. I do have one good spindle and both hubs for the two piece seal of anyone is looking.
- funinthesun95
Glad ...your all fixed up
Willie
Willie
