White 1994 F-150 Sleeper Build
Re: White 1994 F-150 Sleeper Build
Bump pics
- S00TLYFE
- Bronco Info: IT RAPTOR NOW
thing looks rad taylor, give me your bumpers, I know you've found a new idea youd like to try.
Hahahaha, nope, still loving the front and rear bumpers on this thing. They're keepers!
That's where I was thinking of putting the upper shock mount on mine. Let me know what you end up with so I can copy what works haha.
Will do. Right now those are 3.0x10" stroke smooth bodies. I was digging around on the net and figured out that the 3.0 bypasses that Fox sells for the Raptor actually have a .5" shorter compressed length than what I have, but a 1" longer extended measurement, so I may try to find a deal on a set of those and swap em on down the road to get a bit more droop travel.
- S00TLYFE
Travis don't you have a set of raptor take offs for sale?
I actually need the upgraded 3.0 ones that Fox does. Thanks for asking for me though!
So with spring under a 2 link isnt necessary or do you have something else in mind?
As it's been explained to me, spring under takes care of the issues with axle wrap, and a 2 link is not needed.
I was planning on using them not selling them! So I want to see how this goes downS00TLYFE wrote:Travis don't you have a set of raptor take offs for sale?
Do you have an eye to eye measurement on the stock takeoff raptor rear shocks? I'm curious to see how it compares to the 3.0 fox bypasses that they sell in the aftermarket.
This is what I measured eye to eye
Raptor shocks
18" collapsed
29-1/2" extended
11-1/2" stroke
Raptor shocks
18" collapsed
29-1/2" extended
11-1/2" stroke
Yup, those are the same measurements on the aftermarket 3.0 bypass. Interesting...
Do the upper and lower shock eyes have bushings in them? Any idea what the mounting width is? 1.5"?
Look into the King external threaded cap and welded end, very short.
Have they said why not mount the shocks on the outside of the frame? Seems like it would up the stability if not just a little.
Still looks killer though
Would be way more expensive to go outside the frame rails.
Yes, bushings and 1.5" width.nubreed71 wrote:Do the upper and lower shock eyes have bushings in them? Any idea what the mounting width is? 1.5"?
Awesome, thanks for the info! Might have to use those for mockup til I can find a deal on a set of the 3.0 bypasses.
