Brian's '96
Re: Brian's '96
Here's another.
Re: Brian's '96
That might not be a large enough steering cooler. We finally had to go with a medium sized trans cooler.
- funinthesun95
Re: Brian's '96
I would also be game to buy
Re: Brian's '96
Got to put on a few dirt miles this weekend. Had a great time. Need more! The go fast was cut short by a miss that started on the way out there. It got worse as the day went on. Haven't got it figured out just yet. Coincidentally, the #3 primary tube blew out and had a terrible leak. I thought that was the problem, but no change after clearing codes and welding it up. The only code it's displaying is P1101, which is MAF sensor. May need to replace it, but not certain.
Thanks to tcmglx for this shot in a fun whoop section...
Re: Brian's '96
Dual spares time!
Re: Brian's '96
Yikes,
Not sure if you ever picked up the Lowrance HDS7m but can you tell me why you wanted that model? I have a chance to pick one up but I know nothing about gps systems.
Re: Brian's '96
I ended up with an HDS8. Couldn't pass up the deal. Seven was a price point thing. Screen size is way more than an inch different between the 7 and 8.dtbback wrote:Yikes,
Re: Brian's '96
After a couple years of beatings the CV let loose in the rear shaft. Really pleased with the overall reliability I've been getting out of it though. Once I got it strapped up another inch, no more u-joint failures. Woohooo! That being said, just replaced the driveshaft with a unit from CJ Tatton. Great shaft for the money. $260 shipped!! Second time I've used him and will be my go to from here on out. Ordered up a new cv ball and will rebuild the old shaft for another spare.
- funinthesun95
Re: Brian's '96
Are you using the stock size CV?
Re: Brian's '96
Yeah. Just a 1330.funinthesun95 wrote:Are you using the stock size CV?
- funinthesun95
Re: Brian's '96
Bad azzzzzz. So much fun!
Re: Brian's '96
Good thing your in a Bronco, your choice of lines sucks LOL.......
- Phoenix0783
Re: Brian's '96
I think you can get a couple more degrees with 1350s. At least that's what I recall when I last looked into it.yikes wrote:Yeah. Just a 1330.funinthesun95 wrote:Are you using the stock size CV?
Brian's '96
Some of the best bronco pics I've seen! Love it!
Re: Brian's '96
Post the video B!
