92 XLT BUILD
- THEJESUS
92 XLT BUILD
Hey whats up guys thought I would start a build thread since I plan on building this thing slowly and would like to keep you guys posted on it as much as I can.
I will post as I can on whatever little to big project I do
here is some info as to what is done as it is now
Factory: 1992 XlT 5.8l
Engine:
Pacesetter Headers to a 2.5" custom Y pipe to a 3" magnaflow system to stock exit
Mustang 130amp alternator
K&N drop in filter
replaced all plastic vacuum lines with rubber
MSD ignition
Autolite spark plugs
suspension and wheels:
2" lift on clapped out suspension (will be replaced soon)
35" toyo open countrys on 17" eagle alloy rims
Other:
Front brush guard
Rear custom bumper
kenwood radio with a 12" sub
50" top light bar
24" front light bar
here are a few pics of how it sits right now I will be posting as the projects come along
Engine:
K&N drop in filter
MSD ignition
Other:
Front brush guard
Rear custom bumper
50" top light bar
24" front light bar
- _MG_08331.jpg (639.24 KiB) Viewed 2155 times
- _MG_08311.jpg (705.72 KiB) Viewed 2155 times
- _MG_08291.jpg (621.64 KiB) Viewed 2155 times
- keenanduran1
Re: 92 XLT BUILD
Looks good!
- THEJESUS
Re: 92 XLT BUILD
Keena Thanks brotha!
- THEJESUS
92 XLT BUILD
Here is the suspension I picked up for up front
- THEJESUS
92 XLT BUILD
Here are the custom Currie axles for the build
Re: 92 XLT BUILD
Good looking truck. What size springs did you find? Cant wait!
- THEJESUS
92 XLT BUILD
The coilovers are 14" I believe 350/400 lb springs
Thanks
Thanks
- THEJESUS
92 XLT BUILD
Here's a pic from Baja
- THEJESUS
92 XLT BUILD
THEJESUS wrote:Here's a pic from Baja
- Bronco Info: 1996 bronco, 5.8
Re: 92 XLT BUILD
Very nice looking ride.
- THEJESUS
92 XLT BUILD
Thanks Dave!
- THEJESUS
92 XLT BUILD
Time to replace these blown out ranchos
- THEJESUS
92 XLT BUILD
- THEJESUS
Re: 92 XLT BUILD
Ended up picking up a 4" superlift from S00TLYFE will be installing that this week! Looks like i'll be holding off on the coilovers a little longer when funds are right! Im not 100% if I will be installing the radius arms and I for sure won't be using the shocks since I already have new Ranchos. If anyone is interested in buying the shocks PM me or text me 951-760-0141 I'm still debating on the radius arms
- IMG_1572.JPG (193.93 KiB) Viewed 1310 times
- IMG_1571.JPG (404.92 KiB) Viewed 1310 times
92 XLT BUILD
Don't forget that those radius arm drop brackets and the extended radius arms don't go together. It's a one or the other situation. Either stock radius arms with the radius arm drop brackets or stock radius arm brackets with the extended radius arms.
- THEJESUS
Re: 92 XLT BUILD
Good to know! I thought in order to run the extended radius arms I needed to install the brackets as well!
- THEJESUS
Re: 92 XLT BUILD
So I just spoke with someone last night and asked about the radius arms and drop bracket he stated that they do go together. That the drop bracket is there to help correct the caster that is why it hangs lower.
92 XLT BUILD
http://www.superlift.com/4-inch-ford-su ... oC6unw_wcB
Trust me on this one I've installed a lot of these.
92 XLT BUILD
But, you will need either beam drop brackets (not to be confused with radius arm drop brackets) or cut/turned beams with the 4" lift springs.
- S00TLYFE
- Bronco Info: IT RAPTOR NOW
Re: 92 XLT BUILD
Forgot to ask who did your front bumper when you were over last week.
