"Gumby" The 67 F100 Prerunner
I picked this up last Monday.
67 Ford F100
351 Cleveland 2V
C6 with bolt on yoke
4 linked
9" rear end
Reinforced beams
Extended radius arms
Large aluminum fuel tank
37" BFG Projects
17" Robby Gordon beadlocks
Wilwood rear brakes
Art Carr Shifter
80s Bronco center console
1.75" bed cage
1.5" interior cage
Dual Batteries
Just a simple sorta old school prerunner.
Re: "Gumby" The 67 F100 Prerunner
Nice looking 67. How does it drive?
Integrity, Money, Relevance
1amD1cker1@gmail.com
The front is a little more oldschool than the rear Haha. Any plans for it or you just gonna run it as is?
Drives like crap right now... BFG flat spot shake and front end feels like tow out... darts all over the place.
Going to lop those front mounts of and run a coilover and maybe a bypass. Probably have to widen it a little to get good shock angles.
zachwabbit
Post by zachwabbit »
I like this thing a lot!
Potato.
Sweet truck!
Sounds like a good plans. Dibs on the wheels if you go a different route
I do plan on changing the wheels, but there is already two people wanting them. These wheels will stay until I coilover the front end.
96UAV
Bronco Info: 96 XLT --Under Construction--
Post by 96UAV »
Clean! I dig how simple it is. Classic styling.
Philo's coolest ride to date! I don't blame you fro wanting to switch to coil-overs but man, do I love the mold-school multi-shock from ends. Nice Job. I bet that thing will be damn fast in the rough.
Coyote motor fit in there? Can't wait to see Gumby in action, cool rig for sure!
If the back end was more vintage I would leave the multi shock setup. It's cool but makes for 3x the work when valving and rebuilding.
No Coyote motor. If the Cleveland fails I will go to a LS based engine and T400. Don't worry, I'll put Ford stickers on it like this "Dodge" motor.
Today I make a quick hitch so I can move empty trailers between locations.
well done. EVERY motor-vehicle should have a receiver hitch!
Seabass
Bronco Info: 96 bronco
Post by Seabass »
That thing is rad.
Installed some new tires today... upgraded to Toyo 39" race tires. The truck drives sooo much smoother now. Going to have to convert to a full floater and put bigger breaks on it soon.
Got some beam pivots and radius arm pivots from Ryan Piggott / Dezline Fabrication in today. Now I just need to find some 1" kingpin beams (I think mine are 7/8) and some 1 ton spindles with the "bolt on" caliper mounts. Once I have that I can put together a 13" rotor brake package for the front and build some radius arms.
I didn't know Ryan started his own deal
He just started. I believe he is still going to school and working at Ruff Stuff too. Hard working talented guy... I wish him the best on his venture.
1Hondalover
Post by 1Hondalover »
If he answers the phone and fulfills commitments he'll do just fine. If he does he'll already have half of his competition beat. Hope he does just that.
Cool truck Philo.
He is very solid when it comes to responding and fulfilling commitments. I sent payment for these via Paypal and received a tracking number quickly without even asking.
