1989 Bronco Prerunner project
- Jasonj105
- Bronco Info: 1989 Bronco, 5.8, C6
For Sale is my 1989 Ford Bronco prerunner project. It's been caged, has a 5.8 motor with a C6 transmission. It has King coilovers up front with Autofab cut and turned beams. The rear suspension has Deaver f64 leaf springs. It's been converted to the 92-96 front end with Fiberwerx front and rear fiberglass. It's currently not running. It has a new fuel tank, with a new sending unit and in tank pump. It just needs the fuel lines finished and it will run again. I'm asking $3,000 or best offer. Call or text Jason at 760-604-2739. Along with it I will include a bare ford 9 inch housing for it and a brand new beard rear seat that matches the front seats. I have acquired a 75 Bronco and I cant afford to fix up both.
Re: 1989 Bronco Prerunner project
Any pictures that you can post ?
- Jasonj105
Ill post some this evening when i get home.
This looks like a great start for a fun project. I wish I had the money to buy. I would make this one a fun truck and make my other Bronco a pure race setup. Good luck on the sale, Anyone would be getting a good deal on this!
Why is it "currently not running"? Know what it needs to be a reliable driver?
- Jasonj105
I replaced the fuel tank, in tank pump and sending unit. The return line split when I was driving it one time and I pulled it out anticipating running all new lines. Once new lines are in it will run again.
- Jasonj105
To be a reliable daily driver, it would take quite a bit. It doesn't have windows installed, no locks, door panels or anything like that. It was being built just for the desert.
- Bronco Info: 90 Bronco 5.8
I drive by your Bronco almost every day, nice rig.
- Jasonj105
Thank you.
Deposit accepted so the sale is pending. Just awaiting transport and shes going to Colorado.
