PIMP Ecu from stringer performance. Version 1.4
Stand Alone harness with K&N intake.
This is basically a fully tunable megasquirt setup installed in a ford ECU box and pinned accordingly for the ford 60pin harness.
Please research here before buying....
https://www.stinger-performance.com/universalparts.html
I was planning on installing this and converting to C6 but Stinger just released a version compatible with the E4OD.
You will need a wide band O2 sensor.
I’d recommend a new starter kit from them. It is a flash drive with a base tune according to your setup. it ranges between $25-125 depending on what all you want, tuning software, programming cable, etc. lIt is down the page on the link above.
$500obo
PIMP ECU!!!!!
PIMP ECU!!!!!
Gosh darn it! This was supposed to be in parts for sale not wanted. Can admin move it or do I need to redo the ad?
