MAF swap
biggiek
Bronco Info: 92 Ford Bronco
MAF swap
Post by biggiek »
The two wanted ads can be merged. Looking to convert to MAF from SD since I'll be that far into pull g stuff apart. Saw fiveology stuff and it's a good deal but figured I would try as you never know what parrs/kits someone has laying around that they either moved on from or don't need. Mine is a 92 351Ewith E4OD.
LvSteve
Re: MAF swap
Post by LvSteve »
I have worked with the Fiveology with good results
biggiek
Re: MAF swap
Post by biggiek »
I'm looking at them figured I would see what everyone had before buying you never know as plans change etc.
biggiek
Re: MAF swap
Post by biggiek »
Need ecm and the overlay harness...
biggiek
Re: MAF swap
Post by biggiek »
Now in need of overlay harness got everything else....
Re: MAF swap
I have some stuff ...let me look.
biggiek
Re: MAF swap
Post by biggiek »
Appreciate it might as well save some coin to put towards other stuff
biggiek
Re: MAF swap
Post by biggiek »
Anything there Mr fun?
Re: MAF swap
I have some down time now we are back from Mint. I will PM you
biggiek
Re: MAF swap
Post by biggiek »
Still on lookout for overlay harness...
Re: MAF swap
I can get you a factory 95 351 MAF harness - 6025028945 is my cell
S00TLYFE
Bronco Info: None Anymore!
MAF swap
Post by S00TLYFE »
biggiek wrote:I'm looking at them figured I would see what everyone had before buying you never know as plans change etc.
I may have the pin out and swap guide I can send you let me get it scanned before I give everything to Brian
LvSteve
Re: MAF swap
Post by LvSteve »
I would like to see the pin out and guide if you dont mind
