Drum backing plate
- FUFIMI
Drum backing plate
Need a drum backing plate for a ford 9 inch from a 78 bronco. I believe they are the same all the way up to 86. Thank you. Number is 951-956-6922
Re: Drum backing plate
I will look in the garage.
He can habe mine Rob.
I gotta look I might have pitched them already. I have drums but I'm not sure if I still have the covers.
Drum backing plate
Hey will if you're going to disk and getting rid of the drums and Ruben doesn't take them I'll grab them. The ones on mine are toast. Unless Brandon comes up with the explorer stuff.
I'm pretty sure I threw everything in the trash but the drums. I gotta look. I kept them to make bases for a pedistal grinder stand.
- FUFIMI
Thanks for looking Robert. It's junkyarding or disk swap time
I say it's disc swap time!!
Ya I pitched em. Sorry man.
