2-to-1 MAF Y
2-to-1 MAF Y
Looking for a 2-to-1 Mass Air Y. The lower pipe on mine is dry-rotted and cracked.
Shoot me a pm and let me know what you have.
Thanks.
Thanks.
Re: 2-to-1 MAF Y
Plastic or rubber part?Drilim wrote:Looking for a 2-to-1 Mass Air Y. The lower pipe on mine is dry-rotted and cracked.
Thanks.
Re: 2-to-1 MAF Y
The part I need is the 2 hoses that connect to the throttle body and then turn into 1. I'm pretty sure they are rubber
Re: 2-to-1 MAF Y
Drilim wrote:The part I need is the 2 hoses that connect to the throttle body and then turn into 1. I'm pretty sure they are rubber
The two small hoses are rubber, the y is plastic, and the large single hose is another piece of rubber.
Re: 2-to-1 MAF Y
Good call. I need the rubber hoses. I forgot that its multiple pieces.
Re: 2-to-1 MAF Y
I may have what you need. Looks like I am only using the plastic "y" part. I'll know today or tomorrow.Drilim wrote:Good call. I need the rubber hoses. I forgot that its multiple pieces.
Re: 2-to-1 MAF Y
That'd be awesome. Let me know.
- Silverslk
Re: 2-to-1 MAF Y
If not, I just saw two MAF fords in the yard yesterday with them.
Re: 2-to-1 MAF Y
If you wouldn't mind grabbing the hoses off one, Id appreciate it a ton.
- Silverslk
Re: 2-to-1 MAF Y
Post up a pic of exactly which parts you need (that Philo couldn't supply) and I'll grab next time I'm there.Drilim wrote:If you wouldn't mind grabbing the hoses off one, Id appreciate it a ton.
Re: 2-to-1 MAF Y
Made some calls this morning and found a yard about 35 minutes away with a few mass air trucks.Went for a cruise. Got one hose in great shape, one in not so great shape, the "Y" and the tube to the sensor for $10.
Thanks for all the help guys.
