Complete rear end setup 21" travel
This summer I'll be parting with my proven rear set up to venture into the world of 4 link.
My rear set up is dialed and I have never had an issue.
Will include-
Dirt tech rear end- 72" wms, mark Williams nodular big bearing center with spool, 4.88 R&P, currie billet SF ends, 35 spline axles, 12" rotor and gm metric calipers. Fully plumbed tabbed. 5/8 stud.
Giant 64 kit /8" shackles. Two trips on prep/new bushings.
King 3.0 race series double bypass. GIANT link killer layout/valving. Welded uniball ends.
Everything you need for 21" of travel(with frame notch), wide and dialed.
I plan on taking it off after Del Mar Tuff Trucks in June. So you can see it work
I'd like to sell as a package.
Sent from my SM-G996U using Tapatalk
Re: Complete rear end setup 21" travel
Video
https://youtu.be/q-3M4Glt5y8[IMG]https: ... f0ed05.jpg[/IMG]
If you still have this, what are you asking for the package or are you willing to part out? I would be interested in the 64" springs, hangers and shackles.
David
I decided not to link it so this is no longer for sale
Thanks
David
