Hei distributor swap
jeffloya@gmail.com
Bronco Info: I'm looking to buy a bronco
Post by jeffloya@gmail.com »
I have a 85 bronco with a 351, 5.8l. I want to swap to a GM hei distributor. There is a red and green wire on the old coil. Once I spliced on to new pigtail for the hei, the tach pegged all the way over. Does any buddy know how to correct this so I can use my stock tach ?
jeffloya@gmail.com
Re: Hei distributor swap
Is my post being seen. I have got no replies?
Becks_Bronco
Post by Becks_Bronco »
I’ve been watching but I don’t have any answers. Also curious.
Austen2019
Bronco Info: 1986 forb bronco Eddie Bauer
Post by Austen2019 »
Your missing the ground wire to the hei believe black with green there will be two ground wires for the hei to make the tach work. I have more details if you can’t find it text me 7146141097
The distributor cap should have markings telling you how to connect. You need two grounds internally, and external ground, positive power (with key on) and coil (-).
I don't have any images on me now but can circle back. Post photos and I'll help.
