Trailing arms
Posted: Mon Apr 08, 2019 4:08 pm
Figured I'd start with you guys, haven't posted in awhile have a whole new tube chassis truck I built with 4 link front and rear, solid axles wanting to swap the rear to trailing arms vs shock on axle for more travel and to help with more compression travel in the rear I have plenty of room in the rear vs the front, I'm looking at using the ruff stuff trailing arms as my links are almost the exact same length of 48 inches, there's frame mounting is just a poly bushing and won't be up to the task so I need some uniballs with anti wobble bushings built into them with the ability to use a one inch bolt, was thinking of a 1.5 uniball with a misalignment spacer to a one inch hole with some kind of anti wobble bushings, the shock holes on the arms are a .5 inch lower than frame and axle mounting points already in there design, does anyone know where I can get a complete kit or bushings to use for my idea.
Next question, general idea of spring weights for the trailing arm setup, rear is around 700lb corner weight.
