Bronco Rear Sway Bar Kit
DesolateMotorsports
Bronco Info: '92 with a slue of Desolate Motorsports products on it. Long travel, stock width
Post by DesolateMotorsports »
Here at Desolate Motorsports, we take pride in providing top quality suspension products for Broncos. One of those products is our bolt on rear sway bar kit. We are the only company offering such a setup for the Bronco in full kit form. This kit tightens up your rear end and helps reduce body roll on Broncos with stock or modified suspension. This setup is designed specifically for spring over applications with shocks mounted inbound of frame rails, but can be modified for other setups like SUA and some 4-link designs. If interested, please contact us for more details about SUA and 4-link modifications.
This sway bar kit is an excellent upgrade for the average weekender or the hardcore desert prerunner. We have installed this kit on many vehicles since its conception and it has proven itself to be a must have upgrade on and off-road. 8-)
Our Rear Sway Bar kit is in-stock and ready to ship!
Feel to ask any questions you might have about the kit in this thread. Or if you’re already running our setup, chime in with a picture of your rig putting our sway bar kit to use.
Re: Bronco Rear Sway Bar Kit
DesolateMotorsports wrote:This kit tightens up your rear end...
Or rather it actually helps keep you from tightening up your rear end by getting too loose & having a "pucker moment". Nice work as always guys!
Do you have a kit to work on a F150??
If they don't have one "specifically for the F-150 you may be able to use this since the F-150's & broncos run the same springs & front leaf hangers. You can locate the brackets they have here based on measurements from he spring hanger bolts/rivets & use this. Issue I see with that is if the frame is low enough on the F-150 over the spring mount that the tube wouldn't conflict with the frame. Bronco's frames have the step here. F-150's do not so you may be fine. I would thing a quick measurement from them should give you an answer though
F150 frame is a little different. Would have to fit under the bed. It's about 2" off the frame.
cwrisley
Post by cwrisley »
Very cool. Just another item on the "to do" list. It keeps getting longer...
@cwriz
DesolateMotorsports
Thanks for the interest and questions. We will be hosting a SALE this weekend starting Friday (1/27/17) through this Sunday (1/30/17) for Greg's birthday!! Take 10% off all Desolate Motorsports brand products when you spend $50 or more by entering coupon code: "bday10" at checkout.
Some restrictions apply. Not valid on our Front Dana44 Re-gear or suspension kits that utilize king shocks. If you would like to order a kit that has king shocks as one of the included components, we will give you the 10% off the kit components, excluding the shocks. Please call the shop to order a kit and we can get you a price.
All orders must be placed between 1/27/17 00:00:01 PST and 1/30/17 23:59:59 PST for coupon code to take effect.
Have a great weekend!
