Page 1 of 1
Driveshaft loop
Posted: Thu Feb 11, 2016 3:03 pm
by zachwabbit
Have any of you guys used a limit strap or anything else as a safety loop for the front end of the rear driveshaft? I'd like to do something like that since in paranoid about being a Bronco catapult, heard a lot of people use old limit straps, what length did you use and where did you attach it?
Re: Driveshaft loop
Posted: Thu Feb 11, 2016 3:48 pm
by ChaseTruck754
Been a long while since I've seen the setup in person but I seem the remember being able to bolt a limit strap to a crossmember and having it work. Lay under the truck looking at about the middle of the driveshaft & look directly up. Should be fairly easy to figure something out. Length of strap would depend on where you mount it obviously.
