Can anyone measure a 5.0L Bronco oil pan? I need:
1/ The length from at the front of the pressing to the front vertical wall of the sump section behind the X-member.
2/ The depth from pan rail to oil pump area at the front lowest point).
3/ The depth at the rear (pan rail to lowest point of oil sump).
I am having lots of trouble finding a correct rear sump oil pan for the 5.0L here, but I have one from an old race car project (it used the Bronco/F truck pick-up) that MIGHT fit, only I don't have anything to compare it with.
Thanks.
Need oil pan measurements. HELP!
Re: Need oil pan measurements. HELP!
OK, forget about it, then. I've done something different now.
