Santa Came Early!!
- Jasonj105
- Bronco Info: 1989 Bronco, 5.8, C6
Santa Came Early!!
Just picked up a few shocks, tabs and bushings. Hopefully my front suspension build will start soon!
- bajascott
- My belly is my best friend
Re: Santa Came Early!!
right on. what are the plans??
Nice. That Santa's a great guy!
- Rednek Renegade
Dammit santa got my address wrong again. If you could be so kind as to ship those to me
Project el cheap-o
- Jasonj105
The plans are a modified coil bucket with two 12 inch 2.0's. I already have Autofab C&T beams with the stock buckets and dual shocks. I want to build a removable crossover for the engine cage. I think that with the engine cage and shock hoops this setup with be economically friendly and do everything I want it too. When I start the fab work (probably after christmas) Ill get some pictures posted up.
Sweet! Shocks look nice all shiny!! What radius arms are you running?
- bajascott
sounds like you got it figured out.you got a nice combination, should work out great!
- Jasonj105
I have the autofab extended radius arms with bushing ends.
- Jasonj105
Heres the hoops I will be using.
What are the bushings for?
- Jasonj105
Cross member for the shock hoops. Then I only have to undo one side and lift it up if I need to get to something underneath it. I will probably use two for that and two for my two link build in the future.
I would use something solid for the cross member disconnect rather than a urethane bushing. The urethane bushings will allow the hoops to flex which is not ideal.
