BW1356 Output Flange & driveshaft & diff guy & alignment sho
I need a new out put flange for my T-case, but cannot seem to find a supplier. Any of you know where to buy new?
Also need a new driveshaft...again...Banning Driveline has let me down 3 times now, so it's time to find a more reputable source that doesn't need a wad of cash.
Also need a good shop to replace bearings and set the gears up right.
Also need a good alignment shop that knows off-road vehicles.
Not asking for much, am I?
Re: BW1356 Output Flange & driveshaft & diff guy & alignment sho
TLT Tony from RDC
http://www.truelinewheel.com/
But really, any GOOD alignment shop should be able to do it. Stock specs are fine if all the geometry is good.
- kahuna bill
- Bronco Info: auto fab lift, 90 body on 91 frame, e40d, performer heads,jba headers, K&N intake
I went and had my 8.8" and D-44 re-geared by san diego gear and axle. he's out in el cajon. it was two years ago, but if i remember right it was $250 for the labor each axle, i supplied the parts, and he was able to turn them around in two days. i havn't had any problems with either diffs.
1488 Pioneer Way # 9
El Cajon, CA 92020-1633
(858) 449-5656
can't access his website for some reason?
(858) 449-5656
Brian, Measure your driveline. I have 3-4 good ones laying around I was going to take to Leduc.
Thanks Philo. The driveshaft is 25" from flange to centerline of the rear u-joint. Shorty.philofab wrote:Brian, Measure your driveline. I have 3-4 good ones laying around I was going to take to Leduc.
Thanks for the leads fellas. I'm looking for shops in the 909 or 951 areas. Inland Empire.
Inland Empire Driveline in Ontario/Rancho did the driveshafts for the Jeepspeed I used to chase for, never once had one go bad.
Got one:
http://www.philofab.com/temp/driveshaft01.jpg
http://www.philofab.com/temp/driveshaft02.jpg
It's just a hair under 25" compressed. For you Brian, only $50.
Sweet! I'll check it out this weekend. Thanks Philo!philofab wrote:Got one:
- magic carpet XLT
i have a 1356 flange sitting in my parts bin that i don't need. how soon you need it by?
If you make it to Pismo that would be great! Hopefully a good drive shaft will tame things a bit for the drive.magic carpet XLT wrote:i have a 1356 flange sitting in my parts bin that i don't need. how soon you need it by?
- magic carpet XLT
if you need it sooner just let me know and i'll throw it in a box and ship it. you can have it, damon gave it to me years ago and i never needed it so i'll pass on the karma.
