Has anyone used a laser Argon tig welder on DOM steel or aluminum?
I saw a video that made it look quicker than normal tig welding.
Does it get good Penetration?
What wattage did you use?
I am thinking about getting this one? It might be a good introduction to laser welders?
David
Laser tig argon welder
Re: Laser tig argon welder
I have now seen the new Laser welders from Everlast.
They have a 2000 watt version that is perfect for Off-Road fabrication. It works on Aluminum and steel and 1/2" steel in a single pass. They even descale rust and old paint. That is so cool. It also works like a plasma cutter. So 3 machine's in one. At $12k that is not to bad.
David
David
