Greetings Go Fast Friends!
It's time to actually go fast! I did a motor swap in my Bronco years ago (Bronocoyote.com) but never upgraded the suspension and now I have a Solo Stage 4 kit on the way and I'm pumped! The problem is I don't have a clue what I'm doing. I'm self-taught and have never done suspension work before so I welcome advice/help you're willing to share.
Step 1 is borrowing or buying all the equipment I'll need.
Here is the list I have so far...
Air compressor/hose/air chisel (for removing rivets)
Miller 211 Welder + protective gear and accessories
Angle Grinder (cut off wheels and wire wheels)
Impact Driver
Big Socket Set
Regular Socket Set
Big Drill Bits
Primer and paint
4 HD Jack Stands
Crawler
Pack of C Clamp Vice Grips
Metal Marking Pen
WD 40 Penetrant
What am I missing? Suggestions?
Unrelated solved problems I welcome advice on...
1) I need a power steering pump for the Coyote, not sure which one to buy.
2) I tow heavy for brief trips around town with this truck sometimes so would like the biggest + best full disc setup available. Suggestions?
3) I'd like to upgrade the wheels and tires and I'd like the largest and widest rim and largest tires I can fit, suggestions? I have already trimmed the rear wheels wells for paddles and I don't mind trimming the front as well.
Appreciate your guidance!!
Adding Solo Stage 4 to the Broncoyote
Re: Adding Solo Stage 4 to the Broncoyote
Sorry, I meant "unrelated unsolved problems"
For Clyote power steering pump solutions, Id reach out to Power By Th Hour performance shop in Florida...they have/know of options and have lots of coyote swap info..not necessarily into 80+ Ford trucks but in general
Sent from my SM-N975U using Tapatalk
Coyote...robertcrav wrote:For Clyote power steering pump solutions,
I'll look into that, thank you!
- RyanDS650X
Fat fender garage in Gilbert would be a good resource for a power steering pump also.
https://www.fatfendergarage.com/
-shockseals.com
-shockseals.com
Thank you!!RyanDS650X wrote:Fat fender garage in Gilbert would be a good resource for a power steering pump also.
It’s begun!!
Is there an existing thread on this anywhere? I’ve googled and only found a few incomplete videos.
This build is done.
Anyone have advice on how to adjust king shocks for the dunes?
- Becks_Bronco
did Solo spec the Kings when you ordered the kit? Or did you order them somewhere else?
