1996 Eddie Bauer
Becks_Bronco
Re: 1996 Eddie Bauer
Post by Becks_Bronco »
I wanted to use the red S2 as a 3rd brake light when in the dust. The 4 small LED's will work 100% of the time when I push the brake pedal like a normal CHMSL. The red S2 is run via a relay, tapping power from my dust light so that it lights up when I depress the brakes, but ONLY when the dust light is on. Should help prevent getting clobbered from the rear in dust, and let people know where I am, and when i'm slowing down.
I started by identifying the factory trailer brake harness, and the brake light signal wire.
I tapped main power from my Baja Designs S1 dust light.
I used the main power from the S1 to run to a relay, and used the trailer brake signal as the brake signal wire.
Becks_Bronco
Had my shock towers powder coated.
Becks_Bronco
After 4 years of collecting parts, and rolling my install date back multiple times to projects running long, I finally got my baby over to Desolate for the full install. They had it stripped in about a had and a half, and the front in by the end of the week. We opted for ALL of the billet parts...
Becks_Bronco
Realize now I missed some things, a little out of order.
Picked up the rear axle, needed a new replacement shaft due to some wear, but otherwise was perfect.
Installed a Little Shop MFG rear disc kit
Becks_Bronco
Rear shocks rebuilt with Greg's recommended shim stacks, and charged with nitro
Becks_Bronco
Picked up from Desolate, and HOLY SHIT BALLS. I couldn't be happier with the performance, ride, and overall quality of everything. a breakdown of what we did;
Desolate Coil Towers
Desolate Billet crossover brace
Desolate Billet radius arms
Desolate radius arm bracket cross brace
Desolate bolt on skid plate
Desolate cut and turn with mini truss and bash plated beams
King 3.0 IBP Coilovers and King 2.0x2 bumps.
Desolate fabricated front spring hangers
Desolate fabricated rear spring hangers
Desolate extended shackles
Desolate spec Deaver V562 leaf springs
Desolate rear sway bar kit with billet arms
Desolate rear upper shock mount with upgraded billet side plates (first rig with them installed)
Desolate trussed 8.8
King 2.5x12 triple bypasses.
Becks_Bronco
Installed a modular drawer system from Victory 4x4 in the cargo area;
Main drawer is camp kitchen items
Top drawer is tools
Becks_Bronco
Sold my 45L fridge, and ordered a 35. Installed Solo Motorsports cargo shelf brackets. my measurements say the new fridge will fit under the shelf, so I can put ready access items on top, keep the expensive stuff out of sight.
Becks_Bronco
Duplexer installed, since I run two antenna, but this will automatically use the better antenna for either UHF or VHF without me having to do any antenna musical chairs or tuning.
Added some copper foil tape to the shell to hopefully improve the ground plane to the rear. Could be no benefit, but we'll see.
Becks_Bronco
Kind of an as she sits photo shoot. Looks so great freshly detailed.
Becks_Bronco
Shook it down.... of course!
Becks_Bronco
Well September 2023 was a wild month... My job asked me to accept a promotion that included moving from Southern CA to the Bay Area... Bought a house as a single dude. Never something I thought would happen... Packed up my love and my Bronco, and tucked it into its own garage finally!
Becks_Bronco
Headlights were starting to yellow after months sitting outside. Not much to be done there, and Tony and I decided the new suspension needed the newest in LED tech to match. He whipped up a new set of headlights for me, and we did corner markers and ambers while we were at it. In they go.
Becks_Bronco
I've always had a dream of owning an ex forest service bronco. The color is so cool, and it just adds to the utilitarian roots of all Broncos. Underland Offroad has been instrumental in supplying a lot of my parts from King, Baja Designs, sPod etc. With all the work they've put into bringing my dreams to life, we decided that the Bronco is more or less a shop truck for them at this point, and they offered to sponsor a wrap...
Here are the renderings.
We dropped the Bronco off with Elite Shield Auto Spa in Palmdale and the ordered the vinyl to make it happen! (Bronco is becoming an unintentional trailer queen being dragged around the state for work.
Becks_Bronco
Eric at Elite Shield really went all out, stripping the Bronco as if he were getting it ready for paint...
Becks_Bronco
Eric thought he'd give me a heart attack by sending this and saying he thought the color was wrong...
...In reality, the paint on the hood was so bad he had to put down a different type of vinyl to get the final color to lay down and stick without ruining the vinyl.
Becks_Bronco
in just a matter of days, he had about 75% of the wrap on.
Becks_Bronco
Last night he wrapped up the roof, cowl panel, and trim under the headlights.
toddz69
Post by toddz69 »
Looks fantastic!
Todd Z.
Becks_Bronco
toddz69 wrote:
Mon Apr 15, 2024 10:27 am
Looks fantastic!
Todd Z.
Thanks man!
