Tanner's Polished Turd
- tanneraz21
- Bronco Info: 1987 Bronco XLT 5.0
I've been slacking on starting this build thread, partly due to the fact that I seem to not remember to take pictures until it is too late, and everyone knows they check out build threads for the pictures! With that being said Here is my Bronco, slow and steady build with moderate plans for upgrades as my budget allows.
I am going to do a few catching up posts then from there on I'll try to regularly update.
These first two pictures are of when I first got the bronco drivable.
- IMG_0194.JPG (706.13 KiB) Viewed 1149 times
- IMG_0195.JPG (778.5 KiB) Viewed 1149 times
- tanneraz21
Re: Tanner's Polished Turd
Quickly ditched the running boards and rear wing.
At this point I was just driving it to and from work/school to work out some of the bugs. (It had previously sat for about 8 years)
- IMG_1888.JPG (739.19 KiB) Viewed 1147 times
- tanneraz21
Scored a set of 33/10.5/15 Toyo M/Ts for $480 with about 85-90% tread life. This is how I have been driving it for 8 months now.
- IMG_4163.JPG (970.9 KiB) Viewed 1131 times
- tanneraz21
Bought a set of National 3" 10-pack leaf springs at the end of December.
- FullSizeRender.jpg (762.64 KiB) Viewed 1131 times
- tanneraz21
Here are the cores I picked up and started to degrease and hit with a wire wheel, but decided to send them to the sand blaster.
Sent them off to Threat Motorsports and after a quick turn around I drove out to California to pick them up this past weekend.
- IMG_5744.JPG (813.49 KiB) Viewed 1131 times
- IMG_5612.JPG (745.84 KiB) Viewed 1131 times
- S00TLYFE
- Bronco Info: IT RAPTOR NOW
Subbed
Looks good man. Are you in Payson?
- tanneraz21
I live in the west valley, But that last picture I posted was up near woods canyon.RyanDS650X wrote:Looks good man. Are you in Payson?
- tanneraz21
Front shocks came in, rears should be here by the end of the week. I am also looking for extended brake lines. Any suggestions?
- image1.JPG (288.08 KiB) Viewed 1071 times
- S00TLYFE
Got mine from summit for like $60 all 4. Can't remember brand but they're steel braided and nice.tanneraz21 wrote: I am also looking for extended brake lines. Any suggestions?
These look like they would be good. I have had good results with other Russell products.
Although it is not a big deal, some brake lines are not street legal.
These are advertised as street Legal.
https://m.summitracing.com/parts/rus-696490
David...
David...
- S00TLYFE
Actually those are the ones I ended up buying, worked great.
- tanneraz21
Re:
Will they work? application chart says they're for super duty's and excursions?Wrightracing.net wrote:These look like they would be good. I have had good results with other Russell products.
David...
Here is the part numbers for Russell's
David...
David...
- tanneraz21
All new Brake lines, ball joints, alignment cams and pivot bushings
- IMG_5831.JPG (117.83 KiB) Viewed 893 times
- tanneraz21
All new moog stock steering
- IMG_5935.JPG (87.88 KiB) Viewed 762 times
