- 2017-01-10-00-12-56.jpg (392.85 KiB) Viewed 776 times
Andy (eoffroader's) 94 build
Re: Andy (eoffroader's) 94 build
Bronco is looking great. I haven been meaning to stop by TRAC and check it out.
Thanks man its getting there ya stop on by sometime pretty much always there
Finally got the truck runningish it is shifting hard and speedo is not working, cheked all fuses I think it because ofor the abs module I removed I'll check that Sunday when I can next
- 2017-01-13-22-47-04.jpg (467.11 KiB) Viewed 700 times
The VSS signal runs through the ABS computer. You need to jump the wires or plug the comp back in.
I used the info in this thread to not only jump the VSS wires needed but also trace back and delete all the other unnecessary wire, relays etc. and get rid of the whole abs harness.
Oops for got to attach it.....
ABS Removal
https://r.tapatalk.com/shareLink?url=ht ... are_type=t
ABS Removal
Thanks man that helps out alot
- S00TLYFE
- Bronco Info: IT RAPTOR NOW
I have a complete wiring diagram and harness pin out I can send you if it helps let me know
So basically you cut wire #14 and attach it to # 21 - #21 stays attached to that plug I am presuming - do the with #39 and attach it to #22 and leave #22 connected to the computer plug. That technically disables everything - then just do through and pull the wiring out which should just slowly all come out in 1 piece??
Well spun a bearing time to ditch the 5.0 and throw in a 351. Just doing a mild cam for now as budget doesn't alow a 408 yet. Question is I've been researching and some people say they used the 5.0 ecu and had no issues and some say you have to tune it for the 351. Anybody have solid info on this?
- snowman429
- Bronco Info: 93 Bronco alot of work
I'm currently running a 5.0 ecu on a 5.8 with no issues.
Authorized AMSOIL Synthetic oils dealer
For more information or to purchase Amsoil products visit idahosyntheticoils.myamsoil.com
