92 Black Bronco
92 Black Bronco
Started building this 92 a couple of months ago, the owner does not want to cut any corners and wants a fully built bronco utilizing the best parts. The motor will remain stock until the truck is fully completed, then he will be dropping in a built LS or stroker Sbf. This truck will be fully caged and back halfed using 4130 tubing, 70+ gallon custom fuel cell, 4.0 Blitzkrieg rear end, 3.25 rear hubs, 6 piston brakes on every corner, 4 linked with sway bar, 3.5 rear bypasses, 3.5 internal bypass front coil overs, running my one piece 4.5 extended beams and steering, howe ram assist and box, t/c pump, blitzkrieg fabricated knuckles, full tube core support, cbr radiator and coolers, prp seats, 37" tires, autofab glass front and rear, I will post pics as progress continues, enjoy!
92 Black Bronco
Hell yeah get this money dump started. Should rename the thread "everyone's dream becomes reality" haha
Re: 92 Black Bronco
Dear lord can't wait to see how this turns out!! More pics por favor
92 Black Bronco
Agree. More pics n info please. CHO your work looks like art. Awesome build start.
Re: 92 Black Bronco
Really digging the bellcrank you made to relocate the mater cylinder.
Re: 92 Black Bronco
Well this will be a porn thread for many folks! Nice work.
- 1Hondalover
Re: 92 Black Bronco
As usual it appears more great work from you guys. We hope to rehab the front of Jim & Paige's Bronco next Summer with new beams, fabricated knuckles, RCV axles, big discs and King 3.5" IBP. That ought to lighten our bank account some.C H O wrote:
The beams are indeed a thing of beauty and no doubt very bulletproof. With all of the wazoo work and associated parts, what do you do with the ball joint ears to strengthen what appears to be the only OE remainder of this setup?
92 Black Bronco
Thanks for the kind words guys, i will make sure to keep the thread updated with pics. As of now i reinforce the stock lower ball joint ear with plate. I do have billet ball joint ears in the work, not a huge increase in strength but will definitely be a little more bling.
Re: 92 Black Bronco
Im curious, why the owner doesn't want to stretch it.
Re: 92 Black Bronco
Excellent question!D1cker1 wrote:Im curious, why the owner doesn't want to stretch it.
92 Black Bronco
Cause it is a huge amount of work and a stock body wheelbase works great.
Re: 92 Black Bronco
True...butcs_drums wrote:Cause it is a huge amount of work and a stock body wheelbase works great.
I hear lots of bitching about the wheelbase being too short.. blah blah.. Etc Etc
Im not sure if the owner cares about the process of stretching if he's not doing the work.
Re: 92 Black Bronco
My opinion is if he's having all that work done he might as well stretch it now then wish he had later.
Re: 92 Black Bronco
this truck is gaining 4" of wheel base. stretching the cab or shell is not going to happen, that is a huge can of worms that we can't justify doing. this truck will work amazing with the suspension setup it will have, plus we get to keep the beautiful lookof a proportionate bronco with autofab glass.
instagram - @ohhcho
Ideal Fabrication
Ideal Fabrication
Re: 92 Black Bronco
C H O wrote:this truck is gaining 4" of wheel base. stretching the cab or shell is not going to happen, that is a huge can of worms that we can't justify doing. this truck will work amazing with the suspension setup it will have, plus we get to keep the beautiful lookof a proportionate bronco with autofab glass.
Love it
Re: 92 Black Bronco
So I take it you're going to push front forward 2" and the rear back 2"?
Re: 92 Black Bronco
Cho, what's the owner doing with the interior panels? I would love them for the rear cargo panels, and the B pillar if he is planning on dumping them.
