FANCY
- Bronco Info: 1994 bronco 4 inch lift 35's
FANCY
So I've been on go fast for quite some time but never made a profile so here it is!!!
1994 white bronco xlt
Cut and turned, auto fab buckets, auto fab progressive rate could, king 14s and fox hyd bump stops.
Deaver q80s king double bypasses. Custom shock mount. Soon to be a 9 inch trussed, nodular case, 4.10s 1541 motive gear axles.
35 bajas on alcoas
Beard Baja prerunner seats. Crow belts.
Intake, exhaust.
Custom front and rear bumpers, led 20 inch bar and 4 pods.
35 bajas on alcoas
Intake, exhaust.
Re: FANCY
More pics to come, I'm have issues over here... Lol
- image.jpg (1.65 MiB) Viewed 1028 times
Re: FANCY
Nice set up. Any pics of the winch install?
- Cactus Cooler
Re: FANCY
So I finally received my pets from speedway, my 9 inch is coming together. Nodular case , spool, Daytona pinion.
Re: FANCY
Yea those are from Gary's bronco, I bought the front and rear. I actually removed the winch, it was mounted to a piece of 1/2 plate that goes from rail to rail. I'll take a pic tomorrow to show ya
Re: FANCY
Thanks for the positive feed back guys!
So I'm building my 9 inch as I have mentioned and I was curious if anyone is running a quality set of axles with a spool and if they have had any trouble? Or breaking axles and such. I don't beat one car extremely hard but I do enjoy pushing it a bit. These are the axles I will be running. http://m.summitracing.com/parts/MGR-MG25102
Re: FANCY
So I'm building my 9 inch as I have mentioned and I was curious if anyone is running a quality set of axles with a spool and if they have had any trouble? Or breaking axles and such. I don't beat on my car extremely hard but I do enjoy pushing it a bit. These are the axles I will be running. http://m.summitracing.com/parts/MGR-MG25102
Re: FANCY
OK I did some research, 35 spline axles are way out of the budget. I couldn't agree more that 35 spline would be far superior but the old bank account says otherwise! Lol I called currie and Dutchman, I'm looking at anywhere from 6 to 8 hundred bucks.
Re: FANCY
Copy that! What rear are you running yikes?
FANCY
They must have raised prices it was a little over $400 when I bought mine a few years back. But I did supply studs. I still think it worth "finding" the money. I think the rear end is pivotal in a reliable rig. Currie bare 35s shafts are $368. The 31s you posted are $200 ($100 each) the bearings, seals, studs are all gonna be the same cost. Your looking at $170 dollar difference.
