Nighthawk!
Nighthawk!
From what I've gathered from Bray and Josh, GFB members, the math doesn't work. You only get 5 chances before the psom locks out.
Nighthawk!
Yeah it seems high but for stock 30" tires the conversion constant is high 9's. So I think with the fact that the vss kit has a smaller pulse rate with the gears and tires, I feel it's kinda close. I just need the math!
- De$ertBronco
Re: Nighthawk!
I just checked my psom and mine is set at 10.75 with it being off about 1mph. I just guessed a couple times until I got it close. I am not a mathematician and wasn't factoring in the pulses correctly. But hey I am just a parts guy! brian and bray shoulda known better than to trust me!
Nighthawk!
I texted Bray but no response yet. From what I've heard is the leadnav app can be a few mph off and racers are getting penalties for speeding because of it. That's just rumors though. Nothing first hand.
- De$ertBronco
Re: Nighthawk!
oh and my setup is the same as yours currently, so i think you figured out the math! good job!
Nighthawk!
At 65 on my speedo the GPS says 70. Much closer.
Nighthawk!
And for those of you that have converted to rear disks, is there a proportioning valve I can remove? I have a little rest brakes but not anywhere near enough.
- De$ertBronco
Re: Nighthawk!
for anyone else reading this thread we are referring to brandon hollander's VSS relocation kit... others (brea/leduc) would almost surely be a different amount of pulses (magnets/notches). That being said with my psom set to 10.75 and using a gps mine was seemingly dead on until i held it at 65 or 70 where it was a clear 1-2 mph off, but I don't remember exactly at which mph or if it was slower or faster... sorry it was like 3 years ago. At the time I had pretty much brand new 35" bfg a/t ko's (not ko2's obviously, which are probably a different conversion constant) and 4.86 gears as well. I am assuming there will be a slight variation due to tire wear, but I wouldn't think THAT much. I am surprised/bummed you weren't more accurate using the appropriate math. At that point you can still put a couple more guesses in to dial it in before you max the psom out. Anyways you will want an adjustable prop and residual valves.. see brian's (cs_drums) build for reference.
Nighthawk!
Well I burned up both rear axle seals. I've been daily driving it for over a month now with no issues, then we went to the Mojave trail and about 40 miles in I lost the rear right seal. It wasn't bad so I kept running it. A couple miles later I lost the left, now I'm scratching my head, and it's bad. It was a constant stream of oil from both now. I got it to our checkpoint we had setup with a flat bed and jacked the rear off the ground. I tried to turn the tires and the brakes are dragging horribly. A buddy said his axle did the same thing for the same reason. He didn't remove the residual valve and the brakes heated everything so much that his seals melted.
I could barely touch the Lug nuts they were so hot. What do you guys think?
Nighthawk!
Residuals for drums are usually 10lb for disc you want 2lb I ditch what you have and get a 2lb. I've run my set up with no issues.
Re: Nighthawk!
Are there residuals on the factory system?cs_drums wrote:Residuals for drums are usually 10lb for disc you want 2lb I ditch what you have and get a 2lb. I've run my set up with no issues.
Re: Nighthawk!
X2cs_drums wrote:Residuals for drums are usually 10lb for disc you want 2lb I ditch what you have and get a 2lb. I've run my set up with no issues.
Nighthawk!
Do you think I just melted the seals? I have been driving it 20-30 miles one way to work everyday but on the asphalt with non spirited driving and have had zero issues. We were mobbing in the dunes out there and I was driving it pretty hard so I can imagine stabbing the brakes a bunch times doesn't help. I was just going to gut the stock residual. The calipers ratchet so I dint think I need to worry about them retracting.
I've also heard people use the master cylinder off of a 2000 lightning since its disk-disk and all the fittings match and dimensions are the same.
Any experience with that
Nighthawk!
Also forgot to mention that I did the sag conversion and am disappointed in it. Maybe it's a bad pump but I can't turn at all while stopped but as soon as the truck moves an inch I can turn. Is there some sort of modification I can do to the pump to give it more pressure? I also put the threat steering on before the conversion and couldn't turn with the stock pump. I thought doing the sag would fix the issue. I know the threat system has some different leverages but I wouldn't think they're much steeper than the stock steering.
Nighthawk!
Don't you have to turn up the pressure on the sag pump? I don't remember. That swing steering looks to have less mechanical advantage which would make the pump have to work harder.
Nighthawk!
Definitely less mechanical advantage. It's just under a 2:1 ratio. It's pretty nice though only having to turn the wheel less 1 turn each way.
Nighthawk!
And I haven't seen anything about turning the pressure up, I'd like to know how to do that
Nighthawk!
Sag pump should feel night and day. It did on my truck. I had to go back to the stock pump when installed the supercharger. The new stock pump isn't close to the junk yard sag I took off.
Nighthawk!
Yeah it does a smidge better than the stock one and that one was leaking everywhere ave whining like crazy. This one is quiet but just zero turning power when stopped. Even on dirt I can't turn it. Maybe a bad pump?
Nighthawk!
Maybe. So are you the first to run the threat steering? Any input on others with it? My single swing steering gave me more leverage and I can turn my 37s at a stand still on pavement with the stock box, whines a bit but still turns pretty easy. Essentially that same leverage comes back on the sector shaft as well so I need a ram for my piece of mind.
