Jim & Paige's Bronco
1Hondalover
Re: Jim & Paige's Bronco
Post by 1Hondalover »
ChaseTruck754 wrote:I WISH I could trade cookies for parts of that level - rad!
Feeling very fortunate to have this trans Steve. As much as the OE 96 seems to be working good with the Punisher, it has many miles and we don't feel like being stuck in the middle of Baja if it decided to go down. Now when we get to the stroker we'll only need a new rear end to hold it.
I just realized the word "only" is more of a dream than reality in this hobby......
Holy cow, that is sweet Jim!! I'm sure that Trans will last you a good long time.
What are you doing with the 96 that's in there now?
Nice upgrade, Jim!
Deslboy
Post by Deslboy »
you are lucky. My wife won't even let me work on mine anymore!
Did you go full manual Jim? I heard Wood knew how to do that.
1Hondalover
Equipped to do so any time we want, but going to run it OE on the column for now. John says this trans will be as docile or full race as we want it to be.
The Winters removal was designed to keep the operation exactly docile, but with bulletproof performance and reliability.
What are you doing with the trans that is in it now.
Do you have a build sheet and price for the trannybyou could pm me?
1Hondalover
tcm glx wrote:What are you doing with the trans that is in it now.
Sorry I missed the question earlier Tony. The old one goes back in the crate and ships back to John.
1Hondalover
cs_drums wrote:Do you have a build sheet and price for the trannybyou could pm me?
The price is nothing secret so here it is Brian. Although I do have a build sheet, John might prefer the spec remain elusive. With respect for his work I'm going to keep it locked up.....assume you understand.
Many parts including the billet converter are either built specifically for him or machined by John himself, so they won't be available to anyone else including me even if they knew the parts.
12-3-15 John Wood E4OD invoice.JPG (93.33 KiB) Viewed 2235 times
Holy cow!!!!
That is a little less then the Trans I had built for the F350 by Valley Transmission in El Cajon.
1Hondalover
New radiator left Fluidyne today.....waiting for reply from Solo hoping to get it in for KOH fab next week.
J Coffey 5-Row Bronco CM (2) (Large).JPG (264.51 KiB) Viewed 2234 times
J Coffey 5-Row Bronco CM (3) (Large).JPG (229.83 KiB) Viewed 2234 times
J Coffey 5-Row Bronco CM (4) (Large).JPG (224.61 KiB) Viewed 2234 times
Solo seems to be way way backed up. Good luck getting in! Cant wait to see the Bronco at KOH!
tvoymang
Post by tvoymang »
Why did you put the outlet for the waterpump on the passenger side?
That's beautiful
Re:
tvoymang wrote:Why did you put the outlet for the waterpump on the passenger side?
It's a dual pass radiator. Inlet & outlet are one the same side as the tank(s) are split in 2. The fluid goes in and across the fins once, then back across the fins again before heading back out, so inlet/outlet = same side.
1Hondalover
Correct. This is 5 row dual pass. Lots of capability to have cool stuff with a custom radiator.....motor oil heat exchanger on the left side, 3/8" bung for drain valve, intake water connection, grounding hub and mandrel 45 top hose connection for more direct route. Not taking any chances Jim & Paige's Bronco will ever heat again, at idle for 30 minutes with the A/C on or buried in the silt pedal to the wood.
Speaking of not taking chances, our Fluidyne trans cooler showed up today. No way we're going to risk the new E4OD. Lots of work to be done before KOH.....
Fluidyne E4OD cooler dual core dual pass.jpg (251 KiB) Viewed 2132 times
Fluidyne E4OD cooler dual 6.5 Spal fans.jpg (226.45 KiB) Viewed 2132 times
That trans looks awesome!!
Damn!!!!!
