Another Bronco Build
- ChiroMatt
Re: Another Bronco Build
2nd alignment today
Feels better in turns
Think to much on right camber as it pulls a little to left
Less squirly in straight line
Perhaps 1.4 on right ?
Looks Bette when parked too.
- image.jpg (157.41 KiB) Viewed 1409 times
- ChiroMatt
Fab work over the past several months.
- image.jpg (90.18 KiB) Viewed 1247 times
- image.jpg (121.42 KiB) Viewed 1247 times
- image.jpg (115.11 KiB) Viewed 1247 times
- ChiroMatt
Front bumper and rock sliders are on, rear bumper is getting fabricated now.
- image.jpg (120.7 KiB) Viewed 1184 times
- ChiroMatt
Rear bumper with be a double attachment on the passenger side and a single or double on the drivers side. Able to accommodate up a 37" tire and rotopax on both sides.
- image.jpg (109.03 KiB) Viewed 1183 times
- ChiroMatt
Front bumper light tabs and lights installed.
Rear bumper mostly fabbed, just waiting on a couple rotopax mounts.
- image.jpg (99.07 KiB) Viewed 1081 times
- image.jpg (113.36 KiB) Viewed 1081 times
- image.jpg (102.99 KiB) Viewed 1081 times
- image.jpg (112.95 KiB) Viewed 1081 times
Can't wait to see how your rear bumper is going to look when it's completed!
- ChiroMatt
Roof rack installed.
Pondered over the best rack, system or custom, or both, thought about this almost more than the suspension!
Geez.
Went with a Thule rail system that's made for mounting to fiberglass tops( though they don't list a 1996 bronco on the fit list). Plan is to mount a roof top tent and be able to carry some boards, and sups up there too.
Geez.
- image.jpg (85.77 KiB) Viewed 978 times
- image.jpg (63.99 KiB) Viewed 978 times
- image.jpg (100.96 KiB) Viewed 978 times
- 93Broncobuff
BITCHIN BUILD MAN!!!!!!!! a RTT is in my future as well....... Prerunner broncos with overland capabilities are the way to go!!
- ChiroMatt
Thx dt and 93bb
I have looked and looked and have only found two other Broncos with rtt on the net, both are out of the USA!!!
- ChiroMatt
Rear swing tire carrier/bumper lights are wired and working! Nice.
New rear drive shaft with longer spline slip and 1350 is ready for install.
- image.jpg (145.83 KiB) Viewed 954 times
- image.jpg (166.33 KiB) Viewed 954 times
- image.jpg (170.78 KiB) Viewed 954 times
- image.jpg (211.19 KiB) Viewed 954 times
- ChiroMatt
Rear bumper is ready for action!
Nice.
Nice.
- image.jpg (174.65 KiB) Viewed 904 times
- image.jpg (181.05 KiB) Viewed 904 times
- image.jpg (227.26 KiB) Viewed 904 times
- image.jpg (222.79 KiB) Viewed 904 times
I just looked at the alignment specs. It would drive better with a little positive camber in both sides. And it would wear the tires better, too.
- ChiroMatt
StevenG
Thanks for commenting on the alignment.
It still doesn't seem like it's driving correctly
(that could also just be how a ttb drives with 18" of travel!).
B4 the last alignment the top of the tires appeared to lean out vs the bottom.
Now the appear to lean "in" a little too much.
My thots are to wait until all the heavy fab parts are on and load it up then see how she sits..?
Your thots?
Your thots?
- 93Broncobuff
this is one absolutely tripendicular ride!!!!
- ChiroMatt
93bb
Thanks!!! I thinks it's tripendicular too.
Haha
Had to look that one up.
Haha
- ChiroMatt
New drive shaft has solved the vibration under power at highway speeds it over drive or third.
On sweeping left turns there is noticeable grind at highway speeds emanating from the rear. Slight grind on right hand sweepers.
What is this ????
What is this ????
- image.jpg (203.76 KiB) Viewed 731 times
- ChiroMatt
Roof top tent is on!
Think this is only the 4th bronco I have found o Len the net that has one!
And the first go fast bronco with one!
Nice
Nice
- image.jpg (204.11 KiB) Viewed 702 times
- image.jpg (185.58 KiB) Viewed 702 times
- ChiroMatt
More rtt shots.
- image.jpg (200.57 KiB) Viewed 668 times
- image.jpg (226.58 KiB) Viewed 668 times
