Willie's.....1992
- funinthesun95
Re: Willie's.....1992
I will ask for number it is a AFE filter. Box was built with filter when the MAF was done.
- Bronco Info: 1992 Bronco. Caged, Linked and Loud
That should be enough. I will measure and search AFE. Thank you..funinthesun95 wrote: ↑Tue Jun 30, 2020 10:33 amI will ask for number it is a AFE filter. Box was built with filter when the MAF was done.
Well shoot, glitter is not a good lubricant. My helper was not impressed.
- 81415E2F-3A02-43C1-9476-67D473839142.jpeg (447.71 KiB) Viewed 3890 times
- EFE765B6-442F-48D3-BAE4-69685143E91E.jpeg (178.11 KiB) Viewed 3890 times
The Bronco has been parked since July. The trans retired on the 91 coming back from a car show. I lost 2nd gear all together and the slip was really bad before it would move. I limped her home and it’s sat since.
The other day I found a built E4OD that a racer had built for a Prerunner and never installed it. Full updated with everything that could have been done. Kevlar friction plates, upgrades bearing support, upgraded dowels (can’t figure out what this means), all diesel internals and so on.
What I need still.
1. Torque Converter
2. Solenoid pack
3. Trans pan
What I need still.
1. Torque Converter
2. Solenoid pack
3. Trans pan
- 6B241495-FE3D-42DC-9706-1A01EAC5F3D9.jpeg (468.16 KiB) Viewed 3741 times
- 197E3CBF-4610-44C6-ABD1-7297F5B0DC34.jpeg (352.89 KiB) Viewed 3741 times
I have two E4OD units that were built with all diesel internals and HD parts that I will be selling if someone wants to rebuild one. DM me if interested.
Some new parts are rolling in for LIZZO.
Derale Cooling Pan
Dalenzie torque converter (custom)
Derale Cooling Pan
- 1D6D5D59-FA3F-45B0-9989-30A8AD6BC372.jpeg (182.75 KiB) Viewed 3653 times
- 0AF275A4-D38D-45DC-A315-28A00E5CD964.jpeg (188.92 KiB) Viewed 3653 times
The goods.
- 4302A012-2014-4B85-801D-70FDE279E9E4.jpeg (392.57 KiB) Viewed 3608 times
- 6E32810E-D150-4DF7-9972-F4BDC6646D0F.jpeg (298.01 KiB) Viewed 3608 times
- 431C0B45-9038-4C66-BCE0-CD394EF2F102.jpeg (245.64 KiB) Viewed 3608 times
Damn!
A few updates from Southwest Performance.
Solid motor mounts installed and new trans is in. Next up is big boy trans cooler.
- F499500B-E98E-49D5-8AFE-1684FCE392E2.jpeg (339.78 KiB) Viewed 3418 times
- A126FDF4-52AF-4EFA-8467-664014BEF095.jpeg (319.22 KiB) Viewed 3418 times
During tear down I found wild wiring. 1 foot of blue 16awg twisted around a 20awg white wire and taped up. So I am doing some wiring upgrades next week.
- A8ACD929-3603-44A1-8AB8-7BBAE788C0E6.jpeg (139.28 KiB) Viewed 3418 times
- 09A862D9-D237-44EE-9379-24D049166CA2.jpeg (96.63 KiB) Viewed 3418 times
- 7532C89F-79B0-4029-B99A-A3381520DB0D.jpeg (104.48 KiB) Viewed 3418 times
- 6F50464E-41D9-4E0C-96D8-5EF6BBD34D30.jpeg (81.03 KiB) Viewed 3418 times
- 8A45922D-060E-4CF0-9D0D-1CD59CB64043.jpeg (106.14 KiB) Viewed 3418 times
- 92AE07A7-E657-40DC-9881-2A8AED332C01.jpeg (69.36 KiB) Viewed 3418 times
1 step forward 2 steps back. The CBR radiator is leaking. Has anyone used Solderweld? I assume CBR is the best but there may be other options. Any suggestions.
Leaks bad on both sides. CBR has it now. Fingers crossed it can be repaired.
- ED31338C-FA6B-4C50-823A-F9A0CC0C7B5A.jpeg (127.99 KiB) Viewed 3334 times
I use solderweld on aluminum coils in refrigeration but on a microchannel I don't even attempt it unless its on one of the headers or U bends.4WPRusty wrote:1 step forward 2 steps back. The CBR radiator is leaking. Has anyone used Solderweld? I assume CBR is the best but there may be other options. Any suggestions.
New CBR Radiator looking clean. The old unit will be hot tanked, welded and for sale if anyone is interested.
- 6E9FAC06-5E04-4EFA-A29D-C5815CDC31A6.jpeg (404.24 KiB) Viewed 3237 times
30” Rigid Adapt For Sale. Text me if you want it. 951-834-5398
- 0CE65024-4E4A-4D44-B62E-412BAB28CFFA.jpeg (80.67 KiB) Viewed 3237 times
- C3453C4B-9349-4039-B4E5-5821CE189BD2.jpeg (142.84 KiB) Viewed 3237 times
- 0E8887F7-BC47-4412-8C69-1337EDFA3319.jpeg (134.79 KiB) Viewed 3237 times
- THEJESUS
how much will you be selling it for? how soon will it be available?
Bronco is back from Southwest Performance. It’s like a new machine. I am super impressed with what the Marks did with it. I replaced the Rigid Adapt with 6 Rigid 360 series lights. To me it looks way better.
- 57396E6E-6CAF-4842-A1CC-BE9A53D4FE6D.jpeg (58.54 KiB) Viewed 3042 times
- 123B7822-2D4E-4C62-BB3C-C2116B182999.jpeg (72.86 KiB) Viewed 3042 times
- 03ECC72E-6635-4465-B2F2-DA0A8DD7D1DC.jpeg (86.7 KiB) Viewed 3042 times
My UFO
- DDCA39DD-D1D7-4DB3-BDED-EC2809B1276A.jpeg (85.93 KiB) Viewed 3026 times
Bronco For Sale Coming Soon....
Bronco is looking great Rusty...I dig the PRPs, checked them out when it was in the shop
Sent from my SM-N975U using Tapatalk
