Page 12 of 16
Re: Kritter's 96 Bronco
Posted: Sun Oct 07, 2012 2:25 pm
by yikes
shockseals.com wrote:Notice how much the beam pivot moves...time to reinforce.
Saw that, but wasn't sure if it was just an illusion created by the swinger movement.. Thinking I better do the same.
Posted: Wed Nov 20, 2013 5:31 pm
by shockseals.com
picture from 2013 Baja 1000 at RM 268
Posted: Wed Nov 20, 2013 5:44 pm
by robertcrav
Nice!! Saw this posted on FB on KC's page...looks sweet
Posted: Wed Nov 20, 2013 6:16 pm
by ChaseTruck754
pretty sure that's Kris/Kritter's (shockseals.com) truck
Posted: Wed Nov 20, 2013 10:57 pm
by tcm glx
Mall crawler... street driven rig
Posted: Thu Nov 21, 2013 9:44 am
by Bobby Velazquez
Great pic !
Posted: Sun Dec 15, 2013 9:16 pm
by tcm glx
How bout some updates Kris.....how are the three.0s. Get the cargo stuff sorted?
Posted: Mon Dec 23, 2013 8:02 pm
by shockseals.com
tcm glx wrote:How bout some updates Kris.....how are the three.0s. Get the cargo stuff sorted?
shocks are great. Cargo tray/set up is dialed other then needing to mount the air tank.
Working on a tow set up for behind the front bumper this weekend and maybe sneak in a couple more cube lights in the air vents in the bumper. It baffles me Ford made a 4wd vehicle with no tow points on the front. Accordian frame or not, any truck needs tow points on the front.
Posted: Mon Dec 23, 2013 11:28 pm
by AussieRod
WOW!
That pivot does move around a LOT! Glad I made a reinforced one for after the safety inspection
Posted: Sun Dec 29, 2013 10:15 pm
by shockseals.com
Some new additions...
Posted: Sun Dec 29, 2013 10:16 pm
by shockseals.com
That's two hitches mounted flush in the bumper...hard to see since theyre stealth and I couldn't go back and edit the post to make notes.
Posted: Sun Dec 29, 2013 10:30 pm
by philofab
What are the receivers for?
Posted: Sun Dec 29, 2013 11:05 pm
by SteveG
That's perfect, Kris. You could also make a tow-bar attachment to fit those receivers, if you ever wanted/needed to flat tow it.
I'm guessing they're for D-ring hitch adapters, Philo. I'd planned on doing something similar on my Bronco for years....
Posted: Thu Jan 02, 2014 9:52 pm
by shockseals.com
In Baja sur last year when I lost the trans, I strapped it around the frame behind the bumper and it tore the bumper mounts took a lot of massaging to get the bumper back to good looking. Had Ford put some kind of tow points, I wouldn't have had to fix the bumper.
Also for tow bar down the road if I ever buy a motorhome and flat tow it.
Also for a footing to work on it with an aluminum foot I can pull from a pit box and slide in either receiver since I lost the meat of the bumper to the lights.
Posted: Fri Jan 03, 2014 9:37 am
by ChaseTruck754
As usual - well thought out and executed.
Posted: Sun Jan 05, 2014 3:10 am
by AussieRod
yikes wrote:shockseals.com wrote:Notice how much the beam pivot moves...time to reinforce.
Something like this?
- P5220910.JPG (89.77 KiB) Viewed 2120 times
- P5220911.JPG (87.73 KiB) Viewed 2120 times
Bolt on to original holes and helps reduce flex.
Posted: Wed Jan 21, 2015 11:46 am
by shockseals.com
all started about 8 months ago when I forgot to pin the hood and fucked up the a fab hood. Went down to john who offered to fix thte hood free and ended up buying hood, fenders, motor mounts, and trans mounts...stripped all the shit off then it sat since.
a couple weeks ago I sent it out to get finished...
completed cage
remounted new bypasses and bumps
plated frame
new brake lines throughout
80 series land cruiser air cleaner
tinned in wheel wells
pulled the rear fenders an inch further than I had them pulled
radius arms powder coated
all the misc shit mounted
motor and trans mounts installed
glass mounted
beam pivot reinforced
picked up 3-4" of bump travel
now I just need to prep all 4 corners, slap new leafs on, fluid change and get it painted and its ready for a couple more years of pounding.
Posted: Wed Jan 21, 2015 11:53 am
by tcm glx
Drool.............
How/where did you pick up the extra 3-4" of bump? Any pics of the rear flared out?
Posted: Wed Jan 21, 2015 12:05 pm
by shockseals.com
tcm glx wrote:Drool.............
I had limited it to not rub stock steel fenders with 35s and not require any heater box mods then added an inch to that to be safe. Droop is still the same, same limit straps even.
Posted: Wed Jan 21, 2015 12:10 pm
by philofab
I'm interested in that air cleaner... I was going to ask what it was on IG.
