Jb's four door build
- Bronco Info: 94 centurion bronco 5.8/zf many mods more all the time.
Heres a crap load of photos of my build over the last few years.
94 centurion C150
5.8/zf five speed/bw1356-24lb injectors, under drive pulleys, mustang upper plenum, exploder TB, custom intake, mac headers, magnaflow high flow cat, flowmaster 50 series muffler.
Front suspension-Deaver 5.5" super flex coils with ranger lowers, solo c&t beams braced and plated myself, plated rancho radius arms, foa 2.5x14" res shocks.
Rear suspension that i havent started- procomp 6" leafs with overload removed, 7.25" shackles i built, 8.8 with ruff stuff disk brackets and an artec axle truss.
Custom built by me front and rear bumpers, fiberwerx front glass, mcneil bedsides panel bonded on, ebay smoked headlight set, 3 100watt kc's.
procomp 1079 series wheels 17x9 with procomp x terrains 35x12.5's.
Right now im wrapping up the front suspension, waiting on my hoops to come back from paint. Then ill be tackling the rear suspension and from there onto the roll cage. The cage and about 130' of tubing is waiting to be installed. Now onto the pics-
94 centurion C150
Re: Jb's four door build
Finally
- 93Broncobuff
bitchin man!!!
More-
Nice!
Bitchen! Where did you find the gauge face cover?
There from a company called BEM i got them from a board member on fsb for $20. Here a daytime shot.hobbyturnedobsession wrote:Bitchen! Where did you find the gauge face cover?
Nice! Is it a sticker type i take it?
No its a thick plastic with wires coming out the top. Stays in place with thin double sided tape and has its own transformer with dimmer. I wired it directly into the harness for the lights.
Cool. I like it.
Nice! About time someone did a centurion go fast.
Yeah what sucks though is I'm stuck in PA for awhile. One day she will see desert!Nick wrote:Nice! About time someone did a centurion go fast.
You can always trailer it out to the October Baja Run
Lol this is the only thing i own that can pull a trailer. I was thinking more of putting it on the auto train, but i doubt it will happen this year a got to much going on. Oh and my first child due july 8th!D1cker1 wrote:You can always trailer it out to the October Baja Run
Yesterday i got her back on her feet. Still need to get the shocks charged and put in and an alignment. I managed to get 17" from bump to strap. Could easily get more but the center u joint is the limiting factor. If i grind any more out of it i will be into the splines. This is with a d50 stub, im wondering if i could get more out of a d44 stub.
Looking bad ass!
- Kel Fab Creations
- Bronco Info: 95 Bronco
Looks good man.
- 93Broncobuff
bitchin brah!!!
Thanks for the compliments guys. Well the other day i got the body on blocks for the 1" body lift. Broke five out of ten mounts so now im waiting on a delivery. Alot asked why do a 1" BL. Well i needed alittle more room for the 35's and for my extended shackles so i dont have to cut alot of the brace out. Now that its on blocks it looks like i could fit 37's. well again thanks guys.
Way better Nicely done! Clean repair.
