Project Double Trouble/Drew's Bronco
Re: Project Double Trouble/Drew's Bronco
So i got the truck moved back inside shop to start shredding on it again, i bolted everything up and slid my temp. extended axles in to check length and make sure there is no bind. I really thought i was gonna get by without having to clock the third member. but it bound on the drivers side. got the third member clocked and no more bind. crazy just how little it takes to bring it back to spec. so hopefull i can get beams and radius arms finished shortly.
- otter
Is this thing done yet?
Getting there. Been slacking with the holidays. Gonna be at shop new years day hitting it hard! Trying to have her ready for a trip to koh/ leduc swap meetotter wrote:Is this thing done yet?
- otter
Right on. Why don't you post up some pictures. This is a build thread right? haha.
Soon, soon, not a whole lot has changed beside it ending up inside the shop... Stinking family and the holidays! No time for funotter wrote:Right on. Why don't you post up some pictures. This is a build thread right? haha.
Major update today! I got the unibal cups turned down so they fit in stock mounts!
- uploadfromtaptalk1388470403071.jpg (131.93 KiB) Viewed 691 times
How tall overall did you have to go?
I did 1.75 overall, and if I need more I will turn it down some more. First time using the lathe....ChaseTruck754 wrote:How tall overall did you have to go?
Got some more done today, got drivers beam unibal cup tacked in! My hole saw went kapuit while drilling it out so I reverted to a cutoff wheel and the torch. Also stared the v2 of my radius arms. Slowly but surely she is getting there! Passenger has 7 degrees of caster at ride height. 11 degrees of caster at bump and 3 at full droop!
- uploadfromtaptalk1388892448109.jpg (85.4 KiB) Viewed 600 times
- uploadfromtaptalk1388892433598.jpg (103.67 KiB) Viewed 600 times
I'd seat that cup in further (compare it to the bushing) otherwise it might cause other interference issues.
Yeah that's the plan after i tacked it i was looking at it and realized i should've seated it farther in due to trying to move my wheelbase as far forward as possible. thanks for the heads up!AussieRod wrote:I'd seat that cup in further (compare it to the bushing) otherwise it might cause other interference issues.
So shit just hit the fan today!
- uploadfromtaptalk1389489563718.jpg (87.66 KiB) Viewed 489 times
Someone get pissed at you and try to get even via death by plasma cutter? J/k... What happened there?
Was having issues with the dana 50 passenger beam and the axles binding due the the dana 50 beam not being as tall as a 44. Plus the the 50 beam is 5/16s thick. Gonna plate it back and I should have sufficient clearances for the axles.otter wrote:WTF?
Glad it sounds like you have a solution. I'm interested to see the end result. I had forgotten about yours being grafted beams. Good luck brother.
Yeah the drivers beam turned out tits. The passenger beams are the same geometry between both the dana 44 vs dana 50. But the dana 50 has less axle clearances. It cycled fine until I extended 4 inches. So I will cycle it until I have enough travel and re plate beam bottoms.Rmc wrote:Glad it sounds like you have a solution. I'm interested to see the end result. I had forgotten about yours being grafted beams. Good luck brother.
Good solid day getting beam put back together
- uploadfromtaptalk1390108984682.jpg (126.97 KiB) Viewed 373 times
- uploadfromtaptalk1390108958465.jpg (76.52 KiB) Viewed 373 times
Another shot
- uploadfromtaptalk1390109147766.jpg (130.9 KiB) Viewed 373 times
So my next set of dana 50 beam will go so much smoother, my plan after this thing is driving is to start drawing the beams in cad from scratch. using the geometry i want and just cut it all out on plasma table. This gives me somewhere to stretch my CAD drawing skills as well as play with the idea of an equal length dana 50 ttb. So much time into this front suspension cant wait to get it back on the road and put some miles on it.
For those of you guru's
My caster is set at 8 degree's at ride height, at what i believe to be full droop it looks to be around 1 or 2 degrees, and at bump it goes to 12 degrees.
my question is is that acceptable? i forgot to measure stock, but i know most people build more caster into their beams.
