Full Build Bronco 550HP
economig
Full Build Bronco LS1
Post by economig »
Nick wrote:
economig wrote:
D1cker1 wrote:what is that? and what does it do?
Blitzkrieg's fab'd D44 steering knuckle (works on Broncos and I-Beam setups using D44 knuckles). A lot of people will commonly call it a "Spindle."
And some people will overreact towards the misuse of inappropriate nomenclature. If making a quick reference or comparison to *A-Arm uprights, the term is usually acceptable but some people will let it hurt them deeply inside :) These are nice, stronger replacement pieces and they offer improvements for snouts, steering & brakes, etc.
*they cost more than most people's entire front end :)
Dang Willy! Have you been reading the dictionary again!?
Ha ha ha I write a LOT of highly scrutinized documents and sometimes it just kicks in randomly :)
I wanna see this FRANKENCHEVY in action!!! :D
Dan88Rigid
Bronco Info: Full build by Jason Rivera from Race Truck Factory.
Re: Full Build Bronco LS1
Post by Dan88Rigid »
Balls wrote:Why an NP205? Just curious.
Because its easily adapts to a th400 with a Ford style Transfer Case. And when built correctly they are near bullet proof and are very reliable and still affordable
Rigid Industries - LED Lighting http://www.rigidindustries.com/
JAMAR Brakes http://www.jamarperformance.com/
Artec Industries http://www.artecindustries.com/
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
yeah - my question would have been why NOT on the 205?
From what I have heard the 205 is a very stout transfer case. My brother is trying to source one for his Jeep Gladiator(327 chevy, nv4500) but he was telling me the 205s that bolt up to a t400(nv4500) are hard to come by. Is this not the case?
Im dying to see the pics you posted. I am interested in the McNiel 6" bedsides for my build. Havent seen them on a truck. Could you pm/email me a pic if they dont come up soon on the site?
Dan88Rigid
cs_drums wrote:From what I have heard the 205 is a very stout transfer case. My brother is trying to source one for his Jeep Gladiator(327 chevy, nv4500) but he was telling me the 205s that bolt up to a t400(nv4500) are hard to come by. Is this not the case?
Im dying to see the pics you posted. I am interested in the McNiel 6" bedsides for my build. Havent seen them on a truck. Could you pm/email me a pic if they dont come up soon on the site.
The issue with the 205 is they made it for a Ford, Chevy, and Dodge so the ouput shaft is on different sides for each make. For instance Ford is driver side and Chevy is passenger side for front output shaft
I dont know why the pictures arent showing its like that on every Post i see on the website.
Feel free to email me at DanRigid@gmail.com and i can send you pictures.
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
Website issues are the reason for the pics not showing. Hopefully the guys will clear it up soon.
And yes the Ford t-cases seem to be easier to find than the pass side drop chevy ones. Dodge ones are on the drive side as well I believe.
I also THINK Ford was the only one to offer them in both a divorced & married setup in the trucks. Dodge & Chevy both only had married setups available I believe.
Dan88Rigid
ChaseTruck754 wrote:Website issues are the reason for the pics not showing. Hopefully the guys will clear it up soon.
Ok thats good to know.
Yes you are correct on the t-case being both available in the divorced and married setup. Does anyone know someone that builds transfer cases in southern cal??? they are pretty simple but would rather go to someone that knows what they are doing.
Its the last thing i need in the driveline!!!
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
The only downside to the 205 is how much it weighs. Make sure you put a mount off the side of it to the frame like the stock trucks had. Otherwise you run the risk of breaking the tail housing.......
Dan88Rigid
BDKW1 wrote:The only downside to the 205 is how much it weighs. Make sure you put a mount off the side of it to the frame like the stock trucks had. Otherwise you run the risk of breaking the tail housing.......
Yes that is the downfall. Already got that covered. thanks!!
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
Balls
Bronco Info: 84
Post by Balls »
Makes sense, I just figured its kinda different for a go fast build. I know they are bomb proof and can be twin sticked.
They are the poor mans Atlas...... They are almost identical dimensionally and performance wise. They just weigh twice as much..........
Dan88Rigid
BDKW1 wrote:They are the poor mans Atlas...... They are almost identical dimensionally and performance wise. They just weigh twice as much..........
Basically yes. The difference between cost and weight wasnt worth the extra $1400. And were talking about 45lbs which is very minimal when the vehicle is gonna weight around 5,300lbs
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
How wide are those rear rotors?
Are you running the stock hub up front,with that blitz knuckle ?
Dan88Rigid
cs_drums wrote:How wide are those rear rotors?
TubeWorks 14" Stainless Rotor
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
Dan88Rigid
Andy Jones wrote:Are you running the stock hub up front,with that blitz knuckle ?
Yes more then likely
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
Whats the width? They look thin in the pics.
3/8" thick.
Dan88Rigid
ESHALLBETTER wrote:3/8" thick.
correct
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
What calipers are you running? What hubs, rotors and calipers are going up front?
