- funinthesun95
Top is done
- IMG_2833.JPG (64.24 KiB) Viewed 1053 times
Where will the spare tire sit?
I believe he is doing dual spares on the tailgate.
- funinthesun95
To start single spare inside. Just because it easiest
Brian is correct tho...dual on back will come very soon.
Bronco is looking awesome. One of my favorites for sure. Is this down in SD, if so what part?
- funinthesun95
Right now it is not....but home is SD
I am next to SDSU
I am next to SDSU
- funinthesun95
some up dates
- IMG_2849.JPG (63.78 KiB) Viewed 906 times
- IMG_2850.JPG (70 KiB) Viewed 906 times
- IMG_2847.JPG (83.44 KiB) Viewed 906 times
- IMG_2858.JPG (89.82 KiB) Viewed 906 times
- funinthesun95
more updates
- IMG_2846.JPG (82.36 KiB) Viewed 905 times
- IMG_2857.JPG (142.14 KiB) Viewed 905 times
- funinthesun95
you got to love 18 inch shocks in the Rear one at bump as well
- IMG_2856.JPG (113.64 KiB) Viewed 904 times
- IMG_2855.JPG (119.86 KiB) Viewed 904 times
Looking good!
Those H2 wheels look really good!
- funinthesun95
also you will see a gap in the center counsel around radio faces intercom etc ....this was done to make sure when I added interior or some kind to the Dash, I can get material in opening.
- funinthesun95
H2 Wheels are sweet Off set is a little big 5 5/8 Back spacing or something crazy like that.
This has allowed me to use standard fiber glass finders but have 5.5 per side beams. The Dana 50 outer it self adds like 1.5 inches from the knuckle out.
A year or so back people only talked about wider rear bronco glass, so the hummer wheel was planned into the beams and rear end width to make sure no custom glass was going to be needed once complete. Going a Inch or so wider with a 4 inch off set would probably be fine I would just have to trim finders. We will see H2 wheels for now.
I think the H2 wheel look great painted! I didn't know the D50 outer would add 1.5" to each side. Getting a 3" overall width increase while getting greater ball join separation sounds like a really sweet set up!
- RyanDS650X
I like how the wheels are a matching color!
Looks really good Willie !! Between the wheels, matching paint job and your bronco Knowledge you've definitely got yourself a unique bronco. The Cockstar pits are gonna be full of Broncos !!
- funinthesun95
Thanks Guy's.....and yes Aaron, Scotty and Kevin have been giving me hell about the Bronco army that will be helping at Races.
as for the Paint....I was a I don't care about paint guy. It a off road truck.
What I will say on this topic now, is Paint brings positive comments about your bronco even if it stock. Let's be real, everyone loves a complement on something they work hard on or love.
Even if your a bad-ass you like a complement.
I would even say just paint match your glass and it make a big difference.
- funinthesun95
ok enough with the Bling Bling stuff on to the Fab.
Sway Bar clearance, 1/2 inch of shaft showing at bump and bump pads is putting her at 26+ no Drive line.... I know the drive line will not like that....tho.
- IMG_2899.JPG (108.37 KiB) Viewed 804 times
- IMG_2900.JPG (115.96 KiB) Viewed 804 times
- funinthesun95
Some of the info on how we got to the above pictures.
- you can see the Bump stop in full compression in the first picture with 1/2 inch of shaft on shock.
-Sway bar has some room in the next Pic...top is tight.
- IMG_2901.JPG (57.82 KiB) Viewed 796 times
- IMG_2898.JPG (39.77 KiB) Viewed 796 times
