D1cker1 93 Build "The Croc"
Drove fast cars most my life.. but bought a bronco to tow my bike mainly.. But with all the
f350's at the track i want to lift this think and make it look mean..
All while driving it to work and taking off-road but not getting stuck
Uploaded with ImageShack.us
93 EB Bronco 147k miles..
10/2010 Purchased
Replaced:
Spark Plugs, Wires and Distributor cap
Fuel Fliter
Did all of this Due to not passing Smog
------------------------------------------Maintenance-------------------------------
10/2010 Purchased
Replaced:
Fuel Fliter
Oil & Filter ETC
12/2011Purchased new Rear window motor
Fuel Sending Unit
Made a switch for Head lights
removed Rear tire Carrier
````````````````````````````````````````Suspension````````````````````````````````````````
Plans
KING Coilovers 2.5 * 12 and Engince Cage
After looking over the engine Bay. its seems the previous owner did some interesting connections with the
Smog Pump
Vacuum Lines
and some general concerns, but i am looking going through everything slowly
This is a slow build which means its not as fast as some of the others
Bump Stops
Solo Radius Arms and Cut/Turns
Limit Straps
Deaver F53
KING 10" Shocks
New rear Shock Mount
-------------------------------------------BODY--------------------
Repaint.. Stock green/tank
Maybe.... Fiberglass Front Fenders Once suspension is completed
Prerunner Bumpers
6 Alcoas on 35's
10/2010 Purchased
Replaced:
Fuel Fliter
10/2010 Purchased
Replaced:
Fuel Fliter
Oil & Filter ETC
Fuel Sending Unit
Plans
Smog Pump
Vacuum Lines
Bump Stops
Limit Straps
Deaver F53
KING 10" Shocks
Prerunner Bumpers
6 Alcoas on 35's
Re: D1cker1 93 Build "Bucky"
Sounds like a good plan!
12/23/2011
Changed Out My Serpentine Belt.. and Tensioner
It started to Shread.. so i cut a small piece off that was shredding
When i drove it around the block it actually became worse::
The shred had wrapped itself around the alternator
O reailly gave me the wrong Belt because it was too loose
Replaced it with a Gates
Was I finish..... No
The tensioner needed replacing as it was very warn..
Now it runs fairy well
$83.00
$83.00
Update
Scored some Alcoas
Inspected under the hood today and i noticed my serpentine belt is cracked, and looks like its not
in alignment with the a/c compressor..
How do i fix this?
Scored some Alcoas
How do i fix this?
- johncharlesb
My 95 Bronco power steering pulley cracked and when I replaced the pulley the belt was just like that picture. I could not get the pulley to press any farther up the shaft and the pump had excessive fore and aft play in the shaft. The pump needed to be changed out on mine to get the belt aligned.
I will take a look tomorrow and report back
Little Update 2/26/11
Picked up some new items for my build
Picked up a set of Cut/Turns and Engine cage
More Alcoas
33 BFG ATR.. Brand New.. Ouch
More Alcoas
Funny it looks different in person that it does on the internet, "brother".
What kind of bike do you tow? Dirt bike?
That's very true.. I hope that's a good thing.
I used to tow my track bike 1198.. But sold it and I'm
Considering the purchase of a buggy or dirt bike this season.
A Duc huh? I wanted a 848 badly when they came out but after checking the maintenance costs I had to pass. I put 47K on my last bike.
lMaintenance is not bad.. I just rode street because I like going really fast..philofab wrote:A Duc huh? I wanted a 848 badly when they came out but after checking the maintenance costs I had to pass. I put 47K on my last bike.
A race track is fun on a bike.
D1cker1 wrote:Maintenance is not bad.. I just rode street because I like going really fast..
The dealer said I needed some 10K computer to set the valves and 80% of the maintenance couldn't be done anywhere but the dealer.
It is a sexy bike though....
dealers always say that..
The newer ducs from 2010 + the maintenance intervals are about 15k miles.
Nothing rides like a DUCATI.
That's retarded. They lost a 16K sale.D1cker1 wrote:dealers always say that..
- only1mikey
- Bronco Info: 84 Bronco
Nice ride!
Also nice meeting you at the swapmeet!!!
Mike
Mike
Likewiseonly1mikey wrote:Nice ride!
Mike
Eh it's ok... It's no "Caged Bricknose":)
- only1mikey
Meh, cages are only useful if you plan on rolling. Other than that they just slow you down due to their extra weight.
Mike
Mike
- guard
My thoughts exactly!! For me, I spent that weight addition in rock sliders since that's where I was more likely to do the damage.only1mikey wrote:Meh, cages are only useful if you plan on rolling. Other than that they just slow you down due to their extra weight.
Mike
- Pre Run It
- Bronco Info: 93' 5.8 glass F & B 2.5 pro series FOX with Res, Caged, bfg projects beadlocks currie
Re: D1cker1 93 Build "The Badger"
Nice looks like you scored again.
