Tonys 93 bronco
Re: Tonys 93 bronco
Spot on steve! Its a dupluicate of the og one, kind of by design. I reallu liked the og one except for the frame horns, and the corners. This on has a radius around the body which my old one did not. Oh, and I stepped up to four lights.
- Bronco Info: '95 Bronco XLT custom 2.5" lift 32x11.5 BFG AT soon 4 inch and 33's via cut/turn beams
Re: Tonys 93 bronco
I don't know I really like the OG one........Maybe I'm Biased.
Re: Tonys 93 bronco
great lookin truck! keep up the good work
and. . . . . .
If you deside to run the fiberglass . .. . I'll buy your stock fenders
and. . . . . .
Re: Tonys 93 bronco
Couple Easter Sunday updates... no pics though:
Autofab Hood finnally getting installed
Rear poly bumps being swapped out for Bilstein Air Bumps
Silverslk found me a BBK Throttle Body, so picked that up
Dual Battery tray being built
Also Keifer caught a broken shim, so those are being replaced
Pics coming next week........
Re: Tonys 93 bronco
Removing shims, and having the spring pads mounted with proper degree for pinion angle:
Re: Tonys 93 bronco
Rear sitting just a bit lower now:
Hood is on:
Hood is on:
Re: Tonys 93 bronco
T, any measurements on how much the rear was lowered?
Re: Tonys 93 bronco
None yet Nick, the truck is still a Keifers, he is finishing up the rear air bumps as we speak. I'm assuming 3/8" without the shim in their. I can measure it up once she is back home.
Re: Tonys 93 bronco
Air bumps.....
Re: Tonys 93 bronco
Last post:
So, a SUPER SUPER big hats off to Mark Keifer andS Southwest Performance.
He picked up the Bronco a week ago to do the following:
*Mount Autofab double layer fiberglass hood
*Mount a custom set of Bilstein air bump (custom because they are approx 2.5" shorter in overall length)
What he did:
*Found a broken shim in the rear axle, so took off the shims, and rewelded spring plates at proper angle for pinion
*Re-adjust rear 2 links for new lowered ride height
*Found brake line and limit straps were a little too short, so replaced rear brake line with a slightly longer one
*Re-mesured for proper length rear limit straps
*Adjust EGR tube which was causing a rattle
*Program PSOM
*Tighten header bolts
Washed, waxed, and teflon coated (ok, that was a joke, but shet, that would have been the icing ono the cake with all the other goodies he did for me!!!)
Two more pics of the rear air bumps... still need to remove the aftermarket poly bumps I added (which are for sale by the way)
What he did:
*Program PSOM
Re: Tonys 93 bronco
Got a hood prop from the JY, and had it powdercoated. Fit a clip for it as well. Also cleaned up everything behind the grill, remounted the ballast.
- Silverslk
Re: Tonys 93 bronco
Looking good Tony!!!
I have not even painted my bumper yet.....starting to surface rust from sitting outside. I'll try to do something this weekend. Been busy at work with changing jobs.
Re: Tonys 93 bronco
Went dark on the headlights, and grills:
- bajascott
- My belly is my best friend
Re: Tonys 93 bronco
no strike pads on the axle? wtf........
Re: Tonys 93 bronco
hahahahabajascott wrote:no strike pads on the axle? wtf........
Re: Tonys 93 bronco
Nick, this one is for you... went down a little less than 3/8" in the rear without the shims:
Two Andy took while we were heading to the race last weeked:
- bajascott
Re: Tonys 93 bronco
so yea im jealous. looks very nice tony
Re: Tonys 93 bronco
Started working on a stealthbox:
Re: Tonys 93 bronco
What's with all the dirt?
Re: Tonys 93 bronco
yikes wrote:What's with all the dirt?
I have no idea, spent an hour vacumming it!
