My "92" Bronco Build
- valor100
- Bronco Info: 1992 Ford Bronco 5.8 had Pro Comp lift, know it sits on top of Solo 4 over cut and turned TTB's
Made some progress. Got some parts painted this weekend slow, but moving forward. Got the rear leafs and rear brackets off. Getting ready to put the new Deavers on. The lift blocks that where on it when i bought it, where so big i couldn't get her in the garage. Hope to get to the front this weekend. Daughter has no soccer once again so i should be able to get to start on it, once I have the rear back to gether. Painted the rear bracket that houses the leaf black, and the other parts gun metal grey.
- pic #4.jpg (165.56 KiB) Viewed 2772 times
- pic #3.jpg (207.8 KiB) Viewed 2772 times
- pic #2.jpg (232.53 KiB) Viewed 2772 times
- pic #1.jpg (291.95 KiB) Viewed 2772 times
- valor100
Re: My "92" Bronco Build
Here's a few more pic's.
- pic #8.jpg (188.15 KiB) Viewed 2768 times
- pic #7.jpg (187.07 KiB) Viewed 2768 times
- pic #6.jpg (202.71 KiB) Viewed 2768 times
- pic #5.jpg (165.99 KiB) Viewed 2768 times
- valor100
This is some of the parts that i got painted. Still have a few more to paint.
- pic #12.jpg (203.85 KiB) Viewed 2768 times
- pic #11.jpg (193.56 KiB) Viewed 2768 times
- pic #10.jpg (208.28 KiB) Viewed 2768 times
- pic #9.jpg (203.51 KiB) Viewed 2768 times
- Bronco Info: 94 XLT 5.8 4in Rancho with 33in BFGs
Good lookin parts from Solo as always!
- valor100
Yes they are, and they painted up real nicely.
- valor100
I have made more progress this weekend. Got the front end off. Got the buckets removed, and have the frame down to bare metal. That is no fun scraping that black stuff off of the frame. Got my brackets primered going to paint them black. I need to make the rear shock mounts, then i can mount my by-passes. Hope to have the front arms on this weekend hopefully. I'll see how far I get. I'll post pictures when I get home today from work.
- Andy Jones
- Bronco Info: In the Works!
Easiest way to clean up the Frame, is Oven Cleaner! Works every Time!!
- valor100
Andy Jones wrote:Easiest way to clean up the Frame, is Oven Cleaner! Works every Time!!
Thanks for the helpfull tip. I will raid the wifes stash of oven cleaner tonight!
- valor100
Here is some of my progress.
- pic #16.jpg (156.67 KiB) Viewed 2648 times
- pic #15.jpg (170.21 KiB) Viewed 2648 times
- pic #14.jpg (133.91 KiB) Viewed 2648 times
- pic #13.jpg (195.78 KiB) Viewed 2648 times
- valor100
Took it around the block and what a difference the rear was. It was much smoother than before. And that was with just the old shocks still on.
- pic #20.jpg (172.26 KiB) Viewed 2648 times
- pic #19.jpg (261.15 KiB) Viewed 2648 times
- pic #18.jpg (274.09 KiB) Viewed 2648 times
- pic #17.jpg (202.46 KiB) Viewed 2648 times
- valor100
Now i am starting on the front.
- pic #24.jpg (235.71 KiB) Viewed 2646 times
- Some of the old parts that came off.
- pic #23.jpg (253 KiB) Viewed 2646 times
- pic #22.jpg (230.72 KiB) Viewed 2646 times
- pic #21.jpg (182.82 KiB) Viewed 2646 times
Looking good and can't wait to see another widened front end bronco.
It appears the bolt thread will not contact the frame rails, but Steve might suggest reversing the bolt head end inward on the leaf/shackle.
- valor100
Well i got it all back together this weekend. i have to mess with the alinement, and fix the leaking radiator that has suddenly sprung a leak. i also have a rough idle that seems to go away after it is warm. After that i want to take her out near my house and see how it handles now. i have taken more pics as i was putting eveything back together.
- pic #27.jpg (193.21 KiB) Viewed 2516 times
- pic #26.jpg (218.22 KiB) Viewed 2516 times
- pic #25.jpg (261.11 KiB) Viewed 2516 times
Lookin good! Time for some glass!
- valor100
Thanks HTO.
Yea I'm getting closer to that. I,m in Wildomar at times with my daughters soccer i'll keep an eye out for you. I'm just over in Murrieta. And here is another angle. I am going to keep the stock inner fender wells for now till i'm ready to put fiberglass on.
- pic #28.jpg (160.06 KiB) Viewed 2507 times
Definately. With glass, I'm going to have to make mine out of sheet metal. I tried working with the stock ones but its a pain. Do you have the stock radiator? I had problems with mine when I bought it.
- valor100
hobbyturnedobsession wrote:Definately. With glass, I'm going to have to make mine out of sheet metal. I tried working with the stock ones but its a pain. Do you have the stock radiator? I had problems with mine when I bought it.
Yes i think i do. it's the that was in it when i bought it. I'm gonna give Ronny's Radiator a call over in Temecula and see what he has.
Thats a good thought. They have better radiator setups too. I usually try not to buy from autozone or o'reillys but I bought a 4 core from o'reillys and it has metal reservoir ends and its lifetime. I actually screwed up and put a pin hole in it and took it back. They swapped it out with no questions.
- valor100
hobbyturnedobsession wrote:Thats a good thought. They have better radiator setups too. I usually try not to buy from autozone or o'reillys but I bought a 4 core from o'reillys and it has metal reservoir ends and its lifetime. I actually screwed up and put a pin hole in it and took it back. They swapped it out with no questions.
Thats the one good thing about them is that you can take almost any thing back. I once bought a timing belt from Kragons with a life time warrenty. I'm like ok sold, I think the guy screwed up that sold it to me. He's got a radiator for 150.00.
I bought the one for 300 something. Its spendy but works amazing.
