347 Bronco build
RGJ 58
Bronco Info: 93 EB 347 and ZF5 swap undercontruction
347 Bronco build
Post by RGJ 58 »
347 Bronco build + ZF5 5speed swap
After 240,000 miles of very hard abuse my 302 blew a head gasket, I love my bronco and would never want to give it up or stop driving it and didn't want to waste the time fixing the worn out 302, So i decided to take a half build engine that i collected most of the parts for that i was building for fun out back to use in a little mustang street fighter car and finish the engine and swap it in my bronco. That is explains the use of a 347 in a full size bronco not a very ideal combination I know but hey it might be fun we will see i have always wanted a fast bronco. Will mine be fast? or Semi fast? It remains to be seen!
I will be swapping in a ZF5 at the same time if anyone has a cross member from a ZF5 truck i would be happy to buy it from you!
Engine Specs
-Late Model 5.0 Mustang block Bored .30 over, Decked, Line Bored, New Mains
-Forged Steel blue printed and balanced crank by Eagle
-Forged Connecting rods by eagle
-Speed Pro Pistons
-Engine Works Timing Gear Set (Noisy)
-Meling M68 Oil Pump
(Top End)
-Air Flow Research 185cc Heads 2.02 1.6 58cc Chambers
-1.7 Comp Cams Roller Rockers
-Comp Cam XE 282 HR-12
.565 .574 282 292 (Note With the 1.7 Roller Rockers around .30 More lift can be expected at the Valves Est. Final Lift numbers are .595 .605)
-Victor Jr. Intake
-Engine Works HEI style distributor
-Carb?? Haven't gotten it yet thinking probably a 750cfm or bigger tho
I don't know what i am going to Tune the timing to yet if anyone has any suggestions feel free!
My Current suspension is a 4 inch lift with extended radius arms No blocks or spacers all new leafs in the back
I do Plan to use a 75 to 150 shot of NoS as well just for fun
Pics
As the bronco sits now with no engine
Random Engine Build Pics
What do you think Suggestions Comments??
damon1272
Re: 347 Bronco build
Post by damon1272 »
I don't know. A 347 is great in a mustang. 351 power and torque without the weight penalty. If I rember corretcly a 351 is about 150lbs heavier than a 302. If you install aluminum heads you drop another 50 lbs. I don't think you will see a real savings in a bronco on the street. Should run good but no matter how you cut it the bronco is a heavy truck.
RGJ 58
Post by RGJ 58 »
damon1272 wrote:I don't know. A 347 is great in a mustang. 351 power and torque without the weight penalty. If I rember corretcly a 351 is about 150lbs heavier than a 302. If you install aluminum heads you drop another 50 lbs. I don't think you will see a real savings in a bronco on the street. Should run good but no matter how you cut it the bronco is a heavy truck.
Yes sir very heavy just hoping it will have a little get up and go :D
Firetwig
Bronco Info: 1978 Ford Bronco 1996 Ford Bronco
Post by Firetwig »
Faster than stock for sure, for damn sure.
RGJ 58
Post by RGJ 58 »
Firetwig wrote:Faster than stock for sure, for damn sure.
That will make it a lot of fun! I have got to measure out what size push rods i will need Monday and install the timing gears and cover, get the lifters in and get the intake and stuff on trying to hurry up with the engine so i can start on the ZF swap!
