This is my 1981 Bronco build thread....
henri
Bronco Info: 1981 Bronco 400" engine with TMeyer 9,3:3 CR, D44 SAS , deaver coils, Shackle flip, ZF5, NP205,
Re: This is my 1981 Bronco build thread....
Post by henri »
some updates here.... :mrgreen: :mrgreen: ....the TMeyer 9,3:1 pistons (020) are in with the performer edelbrock cam and Ford motorports timing chain set.....
By null at 2011-01-05
By montecarlo at 2011-01-08
Well..I thought I was firing up the engine today....but....when I opened the distribuitor box...some parts were missing.... :banghead: :banghead:
I can´t believe it!!!!!!!!!.
this are the missing parts
Pics from today...
By montecarlo at 2011-01-11
henri
Post by henri »
henri
Post by henri »
This saturday we started swapping in the 400 ......I have some problems cos I´m usin 302/351W engine perches........the right header hits into the frame ..... I´ll be using some engine mounts that are very easy to get in my country bolted to a 1/2" plate and this one bolted to the engine.......so I can solve the issue uf the engine perches....but I think the header will still hit the frame....
This is a friend of mine with a "precision tool" in his hand... :mrgreen:
By montecarlo at 2011-02-12
henri
Post by henri »
well I worked on the engine mounts today.......the engine now sits about 1" rearward....the fuel pump hits the engine crossmember but I´ll cut it to make some space......but I still have problems with the right header.. :banghead: :banghead: hits in both edges of the frame......
By montecarlo at 2011-02-14
Is hiting here....in the lower and upper frame edge....anyone have pics about how to solve this issue??
Uploaded with ImageShack.us
Well today I got the 400 and ZF5 together....and took of the engine perches.......then I placed the engine and trans in the position I wanted.....and now I have enought room for everything.....so now I only have to modify the engine perches to fit the engine the actual position....
Left mount..
By montecarlo at 2011-02-17
Right mount...
Header clearance....
The Zf5
henri
Post by henri »
some updates.....
Home made engine mounts...
Left
By montecarlo at 2011-03-15
Right
Trans crossmember...I used one that I had in my junk.....I think the front driveshaft will hit the left header.... :banghead: :banghead: :banghead: .....fxxxk I hate this headers..... :mad: :mad:
By montecarlo at 2011-02-23
henri
Post by henri »
Adapter for the ZF5 to 351/400
By montecarlo at 2010-12-27
Today pics.....This is what I did this morning....cut a piece of flange to fit the shift rail...
Re-using the tranfer shifter
Used 3 strips of 1/4 metal and welded them...
By null at 2010-12-27
Then I made the thread into the cast iron and used allen bolts
some updated pics....ZF/205 cleaned and pinted...epoxi Black...the same used for the front axle
By montecarlo at 2011-01-22
I always tried to make it work with parts that are easy to find in my country....like the clutch...(I used a set that is really easy to find)
This is what I´ve been doing....
I made a threaded hole to fit the "pivot ball" for the new fork...
By montecarlo at 2011-01-27
I had to grind about 1/4" to get the Clutch Slave Cylinder aligned with the bellhousing bolt
I´weld a piece of cast so I´ll can bolt on the lower bolt.
I welded a piece of cast iron to the bellhousint to fit the second bolt of the slave cylinder
By montecarlo at 2011-02-05
By montecarlo at 2011-02-08
henri
Post by henri »
While I was waiting for the parts for the 400 .... I started with the interior....
By montecarlo, shot with DSC-W50 at 2010-04-22
Jeje...quedo lindo....pero me falta un pedal????.... :idk4 :idk4
By montecarlo, shot with DSC-W50 at 2010-04-22[/quote]
2nd day....I sarted after work at about 6 PM....
By montecarlo, shot with DSC-W50 at 2010-04-23
By montecarlo, shot with DSC-W50 at 2010-04-23[/quote]
henri
Post by henri »
I applyed a butyl rubber frame paint to the interior....aho
By montecarlo at 2010-04-27
then the final step...kind of Dynamat :thumb:
Shot at 2010-04-29
Shot at 2010-04-29
Shot at 2010-05-06
Shot at 2010-05-06
Shot at 2010-05-06
Shot at 2010-05-06
Shot at 2010-05-06
Shot at 2010-05-15
Shot at 2010-05-15
Shot at 2010-05-15
Shot at 2010-05-15
Shot at 2010-05-15
I took off the pedals....cleaned everything and regrease....
Shot at 2010-05-16
By montecarlo at 2011-04-09
By montecarlo at 2011-04-10
