The Farmtruck
bigJake
Bronco Info: 94 Bronco 4" lift and 33's
The Farmtruck
Post by bigJake »
I got this truck when I was 14. With alot of help from my dad I lifted it 4in and put 33-12.50-15 BFG mud terrains on it. It has stayed about the same since then. Only changes have been it is now running on mickey thompson baja mtz's and a few other small changes. The truck has done really well off road but I think it is time to make some changes. I plan on slowly upgrading the suspension because I like to Gofast.
bigJake
Re: The Farmtruck
Post by bigJake »
Here's a view from my back porch in Idaho just for fun.
Lots of room to have fun!
Re: The Farmtruck
Nice Bronco Jake but where's the pic of someone riding down on that inner tube? LOL.
bigJake
Re: The Farmtruck
Post by bigJake »
Whats even better is rolling down the hill in a tube in the summer :D
bigJake
Re: The Farmtruck
Post by bigJake »
The coils on my truck are hitting the shocks. Any ideas what is causing this and how to fix? I want to get this taken care of before I get new shocks.
Re: The Farmtruck
Is your radius arm pivot lowered? If the angle of the beam is right on compression the spring will get pushed backwards.
Re: The Farmtruck
Let me know if not, I have a set of radius arm drop brackets if you cant get the extended radius arms.
bigJake
Re: The Farmtruck
Post by bigJake »
It has radius arm drop brackets. I plan to go to extended radius arms in the future though.
bigJake
Re: The Farmtruck
Post by bigJake »
So the increased uptravel from the lift, but keeping the stock R.A.s could be causing enough angle on the beams to push the spring backwards? C&T beams and extended R.A.s are next on the list after new shocks. Maybe I will try and speed that up a little and be nice to the bronco until then.
Re: The Farmtruck
bigJake wrote:Here's a view from my back porch in Idaho just for fun.
What a beautiful picture. We lived outside Post Falls for 4 years when I was little. I remember seeing white as far as I could see then too.
Re: The Farmtruck
How did those coils work out?
bigJake
Re: The Farmtruck
Post by bigJake »
The coils work great. I am just waiting for some new bilstien 5100s to really test them.
