Brian's '96
Re: Brian's '96
The perfect Man does have a way of bringing clarity to our lives....doesn't he!
It was good seeing you guys today!
- bajascott
- My belly is my best friend
Re: Brian's '96
so whatr do you feed that thing brian??
Re: Brian's '96
Love baby. Love.bajascott wrote:so whatr do you feed that thing brian??
Re: Brian's '96
Lots of oil...lots and lots of oil.bajascott wrote:so whatr do you feed that thing brian??
B, your truck is going to badazzz when you are done!
- Silverslk
Re: Brian's '96
DAMN B!!!! Go big or go home huh?
I guess I'm headed home.
Re: Brian's '96
man those shocks are WHORES!
They've been with 1/2 this site!!!
Hopefully you will finally put them on a truck again Brian.
Re: Brian's '96
They are!ChaseTruck754 wrote:man those shocks are WHORES!
I wanted to keep them, but I don't really need three pairs of 4" shocks. And I know Brian will likely put them to use much sooner than I would have. ENJOY!
Re: Brian's '96
That was about the same reasoning I told myself when I sold them to you. Except I didn't have have 2 other pairs of 4" shocks - just 3"ers.
Re: Brian's '96
Almost ready to start the fab. I'm a bit undecided on how I want to build the engine cage, but it'll come to me. The tires are stuffed about as far as I want to go without moving the wire harness. Coincidentally, that's about the same point the center section contacts the frame.
Is there another OEM part # I can replace the power steering line with? This one is just not right.
Re: Brian's '96
Looks like you have a Saginaw pump on there? I'm not sure what fitting that pump uses but my Ford pump uses hose part number #55712 from Four Seasons and I think Gates is #361020. I have a pressure switch on mine though... not sure where yours went.yikes wrote:Is there another OEM part # I can replace the power steering line with? This one is just not right.
You can have a hose custom made at most autoparts stores. The oem one curves towards the front of the truck rather the around the steering shaft like yours.
Re: Brian's '96
Pics of my stock hoses and pump:
Re: Brian's '96
Looks good B, next step, engine cage!!
Btw, I have your lights, pm me so we can square away.
T
T
Re: Brian's '96
These are so pretty I want to use them! But, they're for sale.
...and these are gonna be mean!
Re: Brian's '96
You leaving the coil buckets off and using the coil kits that came with those shocks?
I have not clue what the spring rates on the coils that came with them are - but I think they are pretty heavy. They were on the front of a class 8 full size dodge the last time they were actually run...
Re: Brian's '96
Yup! Hope she flies. That's not going to be the position of the shock though. Haha!
- bajascott
Re: Brian's '96
i just stand here and hold my pinky up......
its gonna be awsome Brian! im waiting for more progress
Re: Brian's '96
whatever you do with your "pinky" should be kept to yourself Scott!
On a side note - did you get the email I sent this morning and look through the files?
Re: Brian's '96
Cuz it gots a booger on it?bajascott wrote:i just stand here and hold my pinky up......
- bajascott
Re: Brian's '96
haha,no booger just what i do when i see disco trucks and 4" shocks...lol
just messin, i'll stop so we can discuss your build......
