Brian's '96
Re: Brian's '96
Rig is looking great Brian! I like the amber turn signal lenses...and the LED bar will look great with em!
Re: Brian's '96
Is that a lugnut welded on your diff fill plug?
Re: Brian's '96
Lol. Yup. Works great.philofab wrote:Is that a lugnut welded on your diff fill plug?
- rdcjuanb
Re: Brian's '96
So many pages I have read. I dont see anywhere, is this stock width? 35 x 15?
Re: Brian's '96
I believe Brian's 2" over with a 35x13.5x15 Toyo......
- rdcjuanb
Re: Brian's '96
Thanks, thats seems like a great width. Bronco is dialed.tcm glx wrote:I believe Brian's 2" over with a 35x13.5x15 Toyo......
Re: Brian's '96
1.5 over......2 is for ballers.tcm glx wrote:I believe Brian's 2" over with a 35x13.5x15 Toyo......
Re: Brian's '96
Can I ask why you went 1.5 vs 2" over? I've done a mock up with 2" spacers, bfg 35s, and autofab stock width class; it seemed to tuck nicely.
Re: Brian's '96
When I originally built the front end, the intent was to make it Class 3 legal, which meant keeping it under +2/side. Wheel width/offset made up the other .5". End result was slightly over, but workable. Plus 2 is a great width for stock glass, as long as the wheel/tire set up supports it. The extra width of the Toyo's on 8.5 wide wheels might make it too close, but works well with +3 glass.dtbback wrote:Can I ask why you went 1.5 vs 2" over? I've done a mock up with 2" spacers, bfg 35s, and autofab stock width class; it seemed to tuck nicely.
Re: Brian's '96
Thanks for the reply. I'm going to be running the 35" bfgoodrich 35s on Alcoas 5 spokes which are 7.5" wide with 4.25BS. I would love to run the dynapro MT but I don't know if they will clear with +2.
Re: Brian's '96
Looks bad ass
Re: Brian's '96
Tie rod ends are a bit unusual, I like em!
Re: Brian's '96
whats odd about them??
Re: Brian's '96
I'm odd. Haha! The odd part is the sleeve welded over the tube and weld bung. They're monsterous and....well...odd.VintageIronFab wrote:whats odd about them??
Re: Brian's '96
Sweet baby Jesus! Beautiful upgrade man!
Re: Brian's '96
Overkill is underrated!! I like the extra sleeves!!yikes wrote:I'm odd. Haha! The odd part is the sleeve welded over the tube and weld bung. They're monsterous and....well...odd.VintageIronFab wrote:whats odd about them??
