Ryan's '96
- Needles929
- Bronco Info: 95 Part Deux
- Becks_Bronco
Re: Ryan's '96
Those work awesome, and theyre so easy to just pop out when you don't want them in the way
Ryan's '96
The round ones are pretty sweet I love the low profile of them. Picked up 2 new husky totes from home depot too. My action packs were hammered and cracked. The hunskys are nice and like the clear lid, they also fit 2 wide on my table that goes on my spare like inthe above pic for gofast trips.
- Becks_Bronco
Re: Ryan's '96
I ditched my action packers for Front Runner Outfitter Wolf Packs. They stack like legos, and they have vertical sides, inside and out. My action packers took up a lot more space than they could hold because of the slanted sides and the large lip around the lid. https://www.frontrunneroutfitters.com/e ... -pack.html
I like the clear lids on those husky totes.
Ryan's '96
RyanDS650X wrote:The round ones are pretty sweet I love the low profile of them. Picked up 2 new husky totes from home depot too. My action packs were hammered and cracked. The hunskys are nice and like the clear lid, they also fit 2 wide on my table that goes on my spare like inthe above pic for gofast trips.
I’d that a full size table?
Re: Ryan's '96
Its 6' when open.crisis88 wrote:RyanDS650X wrote:The round ones are pretty sweet I love the low profile of them. Picked up 2 new husky totes from home depot too. My action packs were hammered and cracked. The hunskys are nice and like the clear lid, they also fit 2 wide on my table that goes on my spare like inthe above pic for gofast trips.
Ryan's '96
Quick run out to sycamore Creek to check out the water flow after all the rains. Lots of traction and lots of skinny pedal!
- entity-unknown
Re: Ryan's '96
I was up there yesterday. I live in East Mesa so Sycamore is kinda my backyard. Where you at? Wanna trail sometime?
Re: Ryan's '96
Power and McDowell. Ya im down anytime.entity-unknown wrote:I was up there yesterday. I live in East Mesa so Sycamore is kinda my backyard. Where you at? Wanna trail sometime?
Re: Ryan's '96
Went up four peaks a couple weeks ago was fantastic.
- entity-unknown
Re: Ryan's '96
Rock on! I'm on University and Signal Butte. I need some trail buddies cuz goin out alone can be sketchy and bein with Broncos is always better I'm seein if I can get a flat bed and diesel to haul my Bronco to the Stampede this coming weekend but yeah I'll let you know when I hit a trail and feel free to let me know too. Are you goin to the Stampede?
- S00TLYFE
- Bronco Info: IT RAPTOR NOW
Ryan's '96
Tony toldRyanDS650X wrote:Installed my new tie downs today from uscargo. They're the aviation style spring loaded type and worked out great. Getting ready for the SF250.
Me about those tie downs, they’re bad ass I run one in the bed of my truck as well.
Ryan's '96
Annual window motor and gear service today. Also installed 8/32 nutserts in the shitty old wood screw holes that hold the access cover down. Came out tits.
- Becks_Bronco
Re: Ryan's '96
Nutserts are the jam. I've been using those things everywhere i can to replace the shitty self tapper wood screws ford used.
- Becks_Bronco
Re: Ryan's '96
What is your normal routine with the rear window?
Ryan's '96
Vacuum all the loose dirt out. Simple green and a scuff pad to clean the old grease and grit off the parts that move and touch. Then a thin coat of grease (whatever is in my grease gun) on those same areas once they're clean. I move the glass down half way to get all the surfaces cleaned and re greased also. Windex glass inside and out then reassemble. I can always tell when it's due for a cleaning because the glass will chatter when rolling it up about 3/4 of the way up and slow down.
Ryan's '96
Time for some shock service. Ordered 2 seal kits from shockseals.com for my SAW 2.5s on the rear. Thanks for the coozie Kritter!
Ryan's '96
More shock service, Bilsteins this time. Finally got a look inside the ACV on the resi's but forgot to take pictures... pretty unique with a separate piston and valve stacks with the compression side having a spring loaded valve. Both limit straps were over stretched allowing the u joints to bind and passenger axel shaft to rub the window. Got 2 new straps and I'm still playing with ride height.
Ryan's '96
Pics
- Needles929
