95 Black Bronco
Re: 95 Black Bronco
Might want to look at power steering solutions and Psc. Psc has a full kit for much less than Howe. Not real sure how high the quality is though but it's a big seller with the jeep crowd. Might be worth looking into.
motoxscott
Bronco Info: 408 Prerunner
Re: 95 Black Bronco
Post by motoxscott »
Charlie @ PSS is good .... stay away from PSC. Had some friends get their stuff and wasn't happy with the quality compared to Lee, Howe, PSS.
- Scott
C H O
Bronco Info: 1993 Lightning
95 Black Bronco
Post by C H O »
Talked to Bobby at solo the other day, he was super helpful. Think im going to run their setup using a rebuilt ported box, Howe t/c pump, resevoir with filter, pulley and cooler. Image
Re: 95 Black Bronco
Can't go wrong with Howe.
hollandermotorsports
Re: 95 Black Bronco
C H O wrote:Talked to Bobby at solo the other day, he was super helpful. Think im going to run their setup using a rebuilt ported box, Howe t/c pump, resevoir with filter, pulley and cooler. Image
Good choice buddy.
zachwabbit
Re: 95 Black Bronco
Post by zachwabbit »
Dang dude that rear bumper is clean!! Hoping to have something similar made for mine soon
Potato.
C H O
95 Black Bronco
Post by C H O »
Some goodies! ImageImage
Re: 95 Black Bronco
Bad. Ass. Looking damn good!
Re: 95 Black Bronco
That center console is beautiful!!! How did you make it?
C H O
95 Black Bronco
Post by C H O »
Curt at crb built it, it is blended aluminum, same one that was in Gary's red bronco
95 Black Bronco
So tight!!!
cbw
Bronco Info: none.......yet
Re: 95 Black Bronco
Post by cbw »
always impressed with your work cho.
Lets go to Baja
C H O
95 Black Bronco
Post by C H O »
Put in some hours this weekend to install the new steering setup, also double sheered a pair of spindles, welded a backing plate, and put fresh ball joints in. Just need to bleed breaks and the steering ImageImageImage
keenanduran1
Re: 95 Black Bronco
Post by keenanduran1 »
sexxx
Seabass
Bronco Info: 96 bronco
Re: 95 Black Bronco
Post by Seabass »
Did you have the stops added in the box?
Re: 95 Black Bronco
C H O wrote:Got a bunch to tubes done today, got the cage all tacked up and slid it out the back to weld an paint. Still have to to do corner gussets and window v tubes. The cage is 2" and 1.75" fully tig welded, goes through the firewall in 4 spots, fully sealed, stock dash and stock headliner. My seats should be done in a week stoked to see it taking shape!
Hey Cho,
What diameter is the A-pillar cross tube?
carlover
Bronco Info: 95 lt 351w in progress
Re: 95 Black Bronco
Post by carlover »
What rear spring rate did you end up with? I'm looking into building a similar setup and need a good starting point for springs.
De$ertBronco
Re: 95 Black Bronco
Post by De$ertBronco »
Bronco is for sale, someone buy this black beauty! http://www.race-dezert.com/classifieds/ ... &id=115400
