Matt's 1993 XLT Bronco
- 93Broncobuff
Re: Hey guys this is my 1993 XLT Bronco
Just an update:
Baja HID Head light conversion kit....Done
Got 2 inch springs n cams.......Done
Shocks.........il get em tomarrow
Venom comp. chip(my friends idea).........Done!
Il post pics when they are all installed.
- 93Broncobuff
This is a late update but im gonna do it all today hahaha,
So this is how i originally picked my bronco up as...
- P_00029.JPG (159.74 KiB) Viewed 989 times
- P_00028.JPG (115.25 KiB) Viewed 989 times
- P_00027.JPG (163.27 KiB) Viewed 989 times
- P_00006.JPG (172.85 KiB) Viewed 989 times
- 93Broncobuff
New Voltage reg.
- 008.jpg (285.6 KiB) Viewed 979 times
- 93Broncobuff
Putting in new ranch shocks ...... I had a buddy also weld a bracket that broke.
- 035.jpg (236.08 KiB) Viewed 973 times
- 038.jpg (292.19 KiB) Viewed 973 times
- 039.jpg (203.59 KiB) Viewed 973 times
- 93Broncobuff
Went out to Granite Cove and had to pull an Exploder up n over this hill when my tow cable snapped!
The hook shot strait at my tail gate, shattered my rear window cus i had it down, and left me with a pretty good gash.
- P_00025.JPG (102.85 KiB) Viewed 972 times
- P_00026.JPG (74.51 KiB) Viewed 972 times
- P_00024.JPG (183.33 KiB) Viewed 972 times
- P_00023.JPG (240.92 KiB) Viewed 972 times
- 93Broncobuff
Whent out to Big Bear area to do some hiking when my dad thought it would be cool to drive through this lake. It wasnt very deep but apparantely it was deeper than we could have done because we sucked up water into the engine, siezed it up and bent three rods......I guess water doesnt compress very well lol My father later forkerd over another block about 3 days latter! After that we desided to put on a snorkel.
- SSPX1322.jpg (256.88 KiB) Viewed 970 times
- SSPX1321.jpg (291.95 KiB) Viewed 970 times
- New Block and head.
- SSPX1332.jpg (241.59 KiB) Viewed 970 times
- Old air intake system.
- SSPX1331.jpg (227.08 KiB) Viewed 970 times
- 93Broncobuff
Putting on the snorkel...
- SSPX1320.jpg (286.67 KiB) Viewed 968 times
- SSPX1324.jpg (164.23 KiB) Viewed 968 times
- SSPX1326.jpg (224.16 KiB) Viewed 968 times
- SSPX1334.jpg (276.62 KiB) Viewed 968 times
- 93Broncobuff
So the only way to use the snorkel was to basically change the whole air intake sytem. I used abs pipe n fittings as well as a peice of copper pipe i had to bend to fit and a 1997 expedition air intake housing and filter.
- SSPX1338.jpg (235.5 KiB) Viewed 964 times
- SSPX1339.jpg (230.85 KiB) Viewed 964 times
- SSPX1340.jpg (299.26 KiB) Viewed 964 times
- SSPX1341.jpg (241.88 KiB) Viewed 964 times
- 93Broncobuff
Put in the new K&N air filter as well as take out the bench seat.
- 005.jpg (299.54 KiB) Viewed 962 times
- 006.jpg (287.94 KiB) Viewed 962 times
- IMG_0179.JPG (283.33 KiB) Viewed 962 times
- IMG_0178.JPG (283.73 KiB) Viewed 962 times
- 93Broncobuff
Before i found a love for going fast in the desert, i wanted my bronco to be an all out expedition rig so i got a winch bumper off of JBG, my dad had it chromed, i got 2 hella's n made some welded brackets for 'em as well as pick up an after market black grille n head light brackets. the pic of me is when i was putting in daystar leveling pucks in the front under the coil.
- P_00106.JPG (146.83 KiB) Viewed 960 times
- puting in the 2 inch lift.jpg (20.03 KiB) Viewed 960 times
- IMG_0174.JPG (238.19 KiB) Viewed 960 times
- 040.jpg (219.34 KiB) Viewed 960 times
- 93Broncobuff
Some more pics, also picked up a rack from Defender racks n 4 pro comp lights, n had the rack bedlined. And if you didn't notice, i work for Domino's as a delivery driver.....perfect car right
- IMG_0169.JPG (298.4 KiB) Viewed 957 times
- IMG_0175.JPG (280.73 KiB) Viewed 957 times
- 048.jpg (287.69 KiB) Viewed 957 times
- IMG_0172.JPG (257.51 KiB) Viewed 957 times
- 93Broncobuff
My Dads plumbing rig
- IMG_0171.JPG (289.09 KiB) Viewed 957 times
- IMG_0170.JPG (298.38 KiB) Viewed 957 times
- IMG_0168.JPG (289.04 KiB) Viewed 957 times
- IMG_0167.JPG (227.73 KiB) Viewed 957 times
- 93Broncobuff
I hated the center consol that came stock so i made this one out of wood n then carpeted it......it came out of but im looking for a better one that is done profesionally ....
- IMG_0176.JPG (254.56 KiB) Viewed 957 times
- IMG_0177.JPG (235.4 KiB) Viewed 957 times
- SSPX1335.jpg (214.62 KiB) Viewed 957 times
- SSPX1336.jpg (221.08 KiB) Viewed 957 times
- 93Broncobuff
New Baja HID's from Tony!!!!
- IMG_0211.JPG (186.58 KiB) Viewed 956 times
- IMG_0210.JPG (261.31 KiB) Viewed 956 times
- IMG_0209.JPG (241.14 KiB) Viewed 956 times
- 93Broncobuff
Go Fast Stickers, New Venom Chip, and Moog 2 inch spings.
- IMG_0227.JPG (298.55 KiB) Viewed 955 times
- IMG_0222.JPG (213.35 KiB) Viewed 955 times
- IMG_0221.JPG (299.69 KiB) Viewed 955 times
- IMG_0219.JPG (289.62 KiB) Viewed 955 times
- 93Broncobuff
What are your guys's thoughts on the Venom chip.....my buddy told me its perfectely safe n what not but my dad swares i will fry my engine. I havent wired it up yet just sitting in my garage for now....
- Agui-E7TE
Re: Matt's 1993 XLT Bronco
I noticed you said in another post that you were going to install 2-Inch leveling coils and run a fabtech block in the rear. If I were you I would just run the 2-inch coils since that will make it sit better. There's already enough room to run 33's that way and it will ride so much better without a lift block. That's pretty funny about using your Bronco as a delivery truck, If I ordered pizza and the dude showed up in a Bronco I'd tip him extra, haha! Gotta hook 'em up with gas money!
- 93Broncobuff
hahaha ya ppl love my car when i show up. One reason im runnin the blocks is cus i already have daystar leveling pucks up front for the accomidation of my bumper cus its so heavy.
- Agui-E7TE
It might work then but I'd be weary of running the pucks and the dual rate coils. It should be able to hold the weight easily and the reason it would concern me is that your alignment cams might be set up for only the 2-inch lift coils and not the extra height of the puck. Just something to think about before installing everything.
- 93Broncobuff
Oh ya na man im gonna have to get a searing stabalizer n such.... The Big O Tires, who have been very good to me said it would be no problem to aligne it with a stabelizer.
